This video show the utter importance of always demagnetising a watch before attempting to regulate it.
I saw that one last week. It was interesting to note that he demagnetised it in two positions, one at 90 degrees to the other.
Actually I was wondering why did he do so... is there any special reason?
    • Like these? https://www.watch-tools.de/metal-straps/springbars/assortment-360-strong-spring-bars-beco-inox-o-1-8mm.php
    • I've seen them on several swiss-made movements as well. Last one was a Tissot if I remember correctly.
