I designed and printed this.  It has a bearing embedded in it with a small clearance to create a nice rotation feel.  The PLA I used prints beautifully and allows you to sand it a little which creates a tactile smooth finish.
  • Like 6
  • 5 weeks later...
omg, beautiful!!!
I love making tools and accessories. Youve done a great job!
I just finished modeling and printing a watch spring winder. Currently im fitting the parts together.
So nice to be able to draw up a print for something you want.
Print at 0.1mm.  No supports if your printer is good a bridging.  The bering is a standard 12mm hole, 24mm diameter, 6mm height.  You may need to put a small paper shim above the bering to bring it flush with the bottom of the mid section.  It depends on how good your printer is at bridges / supports.
Tell me how you got on.
TweezerStandTop.stlTweezerStandBase.stlTweezerStandMid.stl
Edited by AshF
    • Not centered to begin with.
    • Agreed. There are many different automatic winding mechanisms, each with their own quirks wrt. lubrication. Access to the specific service instructions is the ideal. Otherwise, ask here for advice on the movement you are working on.
    • I put the original broken glass (whats left of it) behind the acrylic. This is how it originally looked like. A cheap clock but I like it. Very noisy when the alarm comes wake up guaranteed! 🙂
