Ball bearings for clock bushings
HectorLooi
I came across a video on YouTube where a worn bushing was replaced with a ball bearing. The repaired wheel was able to spin freely for a very long time.
If you fast forward to around 6:00, he shows a worn 2nd wheel hole replaced with a ball bearing. (OH, please look past the use of a power drill to enlarge the hole.)
What are your opinions on the use of ball bearings?
Well I just watched it all and I would suggest that he has not achieved very much at all. If you watch after 7:45 minutes, maybe it is the refresh rate on my Mac, but I cannot see the bearing race actually turning when he is spinning the wheel. Also, as he has the bearing on the top plate of this wheel in his demonstration the wheel would be sitting on its lower pivot on the bottom plate as he shows the bearing slipping onto the top pivot at 7:07.
I am not an experienced clockmaker, but I don't think there is any advantage to doing this at all. If the pivot spins in the inner race, the pivot will wear away now as the race is hardened. When the pivot is in the brass plate, the plate wears away. That would no longer happen in this case. Also, if the bearing happened to 'walk' out of the movement plate for whatever reason, the damage that would happen then would quite likely ruin quite a few parts.
I see two things wrong with this. The first he has removed far to much brass in order to fit that ridiculous bush. You are supposed to remove as little as possible of the original. Second it is not in keeping with the clock, it sticks out like a sore thumb, again you repair as near to the original as possible. I watched a few of his videos and I'm not impressed at all. If I had my way 99% of videos I watch on Youtube about clock repairing I would remove. They give skilled repairers or restorers a bad name.
Any new clock repairers on this forum. Do not follow what this idiot is showing you and avoid his videos.
Ok, noted. I like to explore new ways of doing old things. One material that has intrigued me for a long time is Aluminium Magnesium Boride (BAM). It's supposed to be one of the hardest and most slippery substance known to man.
https://en.m.wikipedia.org/wiki/Aluminium_magnesium_boride
However, I have not seen any real world applications of this material. Can you imagine if we had bushings or bearings made of this ceramic alloy. If we could coat metal surfaces with it, we could have machines that would never wear out.
And there lies the crux of the matter. Which manufacturer would invest in a technology that could put them out of business.
Hi Hector if only.  The machines of today have built in obsolescence with a life of 5 to10 years max. And as you rightly say what manufacturer would embrace a technology that would give bearings and bushings a life time of use. Such technology would put manufacturers out of business.
While I'm for the use of new technologies and materials, I do draw the line when it comes to doing sacrilegious things.
Like whenever I see a vintage clock that had been gutted and fitted with a $2 quartz movement. And the smug seller advertises it as repaired, fixed and modernized. ?
There is no other way, than repair as un obtrusivly and as near to the original as possible keeping the whole clock intact as is. I repair quartz clocks, and when ever possible repair the same unit or re fit a unit as close yo the original as possible.  We can all lob in a cheap chinese unit costing a £1 and make it work.  I have seen some nice clock cases that have been "converted" using cheap units, the clock is then ruined. Most clocks can be repaired but as ever its economics, down to cost.  How many good clocks have suffered with that in mind. Hundreds.
When I first watched this I did so without sound. (in our lounge and others were watching TV)
I just listened to it with sound. What a mess of a video. It chops and changes between topics (i.e. the preacher moment) and I have only just heard & noticed that he used a bushing inside the inner race of the bearing. What an absolute waste of time and effort as well as looking completely out of place.
I'm with @oldhippy. Not a very instructional video.
I guess it's also because the clock was not designed for ball bearings and the bearings were not designed for clocks. If it were executed correctly, the clock could potentially be maintenance free. But I can already hear the clockmakers scream "Why would we want that?"
I like things that lasts forever and need practically no maintenance. It's probably a trait I acquired from having too many expat teachers from Scotland. ?
The ball bearings are marketed by Butterworth clocks in the U.S., a distributor of German clock movements. As I understand it, the bearing mod came about as a result of the terrible plated pivots some of the German makers started using in the last quarter of the 20th century; many clockmakers feel that once the plating starts to peel off, the soft steel underneath is unsuitable as a pivot, so you either repivot or replace the whole wheel. With the bearings (installed as intended), the pivot is a firm fit in the inner race via a bushing, and voila. It seems initially they were just for the great wheels, now with cheap miniature bearings they are marketing them for more.
They also sell a "pivot polishing system" which looks like a time consuming way to make crappy pivots- just went to find a vid (there are a couple), and had to laugh out loud- our dear OldHippy seems to have commented hahahahahaha.
  • Sad 1
Dear God!!!
haha... classic case of 'a solution in search of a problem' . The balls are not moving.. (7.55). If the bearing was working properly they would roll around. The bearing looks like it will be thicker than the plate.. this means it will not be really secure..
Interesting but ultimately pointless.
Anilv
On the question of pivots I've notice you can now buy "quick pivots" which looks like they fit over the the top of the old part. not having a lathe to make new ones this does seem like a simple solution but what do people think? are they any good?
You're a brave one. I didn't dare ask OH any more heretical questions lest he excommunicate me.
I think it should work but I think a lathe is still needed to cut off the old pinion and shape the arbor to the correct diameter to fit into the quick pivot.
Then I suggest the Unimat 3 this is what I have and it will handle anything right up to Longcase clocks including the barrels and center wheel. You can still buy accessories even though most are second hand. Some of the lathes I have seen on ebay even have the milling attachment (you can get that separately if you wish)
As I have posted...when a teen, my dad paid me to do his clock work for the shop.  I will not reveal any of my repair stories at the risk of being tossed out on my arse!
Now in my golden years, I aspire to perfection--reading and absorbing all of this good knowledge--atoning for my past sins.
    • I have been recently servicing an Omega 3220A chronograph movement which uses a Dubois Depraz 2000 chrono module.  This has been quite a time consuming project, not necessarily difficult but with lots of steps.  Working on the chrono module is like working on the love child of a hugely complex keyless works and a Timex pin pallet movement. I do have access to a couple of Omega tech sheets and a couple of relevant Youtube videos (including Mark Lovick's Breitling series) so I feel confident that I have all of the required information. The 'tractor' movement (effectively an ETA 2892) had no issues with obtaining 300 degree amplitude dial up / dial down and maybe a spread of 7 seconds across all of the positions.  I serviced the chrono module and when reinstalling it, this brought the amplitude down to about 260 degress with the chrono stopped and 200 with it running.  The Omega specification states that the chrono running should see the amplitude drop by no more than 40 degrees (from, I am guessing, the assembled amplitude i.e. chrono stopped rather than just the bare tractor movement). Obviously this isn't good enough. I am going to have to redo the chrono module again.  Where I suspect I have a problem is inconsistent / over oiling of pivots.  For some reason the Omega technical guide states to apply oil to the bottom pivot of each wheel and then place in the jeweled base plate.  In practice, I managed to smear oil on the horizontal base of the wheel which would be smeared over the outside face of the jewel.  This also wouldn't be helped by dragging the wheel around trying to get the lower pivots to engage in the the jewel.  When I watch Mark service a similar Breitling chrono with DD module, he also oils the bottom pivots and installs the wheels (obviously doing a better job than me!).  My question is, why can't I install the wheels dry and the oil the jewel on the other side of the base plate in the conventional way? The top pivots are oiled through the jewels in the conventional way, so why would the lower pivots be any different? Looking at the those jewels (picture below an example from a different movement) it looks like there isn't an oil well in the outside surface of the jewel around the pivot, so perhaps I would be better applying a drop of oil directly to the jewel hole before installing the wheel?  Perhaps the jewels have different arrangement to conventional jewels because the outside face is installed against the dial side of the tractor movement and we don't want to risk oil migrating from the module to the movement. There are also a couple of friction springs that may have an impact on amplitude, I will recheck their pre-load but these should be OK.  Is there anything else I should look at as a source of friction in the DD module?
    • I found a Trupoise in a flea market box of tools (🇬🇧car boot). I preferred the ‘8’ style tool until the moment I broke my new Omega rivet. The trupoise holds the arms firmly and I’ve become quite efficient… …and I just resorted to bending a balance cock. I needed a tiny bit less shake and it seemed the least risky of the other options. I held it between a stump and a fat stake while I bent the jewel end with my fingers. Honestly I don’t know how anyone would know by visual inspection.
    • It was about 4 years ago, one was 30, another 35 and 2 others came in joblots that I was after something else. 3 have ruby jewels and one has ceramic bearings.The most I've seen one sell for is £330.  In the uk i still see them sell occasionally for around £70.  I'm not convinced that the Trupoise has low enough friction on the pivots to be as good as a traditional tripod poising tool with unworn ruby jaws.
    • I have a Record 525 which is in a pretty bad way. From what I can see it is based on a cal 650 with an automatic bridge and centre seconds pinion under the rotor retaining stud.  There are additional bearings in the train bridge for the bottom pivots of the automatic works. Of these, on has come out of the bridge completely, one is a bit mangled with an egg shaped pivot hole and one is half in, half out. I've made bearings from scratch on the lathe before, but only for pocket watch pivots (i.e. considerably bigger than these!) and these bearings are either plated or not brass, to match the bride plate, I would guess. I could not find a bridge on eBay so I started digging. I checked new Ranfft site (not help, but the new one seldom is) then the cousins download centre but I could not find a document for a cal 525. I did, however find one for the 650 and, scribbled on the page are the words "= Longines 701". So, obvious next step (or so I thought) would be to check the docs for Longines cal 701 and then see if there is maybe a cal close by, based on that cal with a rotor. I checked, no 701 in the downloads section.  I did find some Longines 701 parts on eBay, which look similar to the 650 (i.e. the train bridge looks to be the same) but I feel I have hit a dead end. I have added some pictures that you may find helpful and I have photographed the entire strip down so I have more, if needed.  I feel I have few options: 1. Close the brewing holes up and reinsert the loose bearings. Close up the pivot hole on the 3rd bearing and hope that does the trick. 2. Make some new bearings (doable but tricky and will look wrong) 3. hold out for a 525 bridge to come up online. I get the feeling this is a rare movement though (all the more a shame it is in such a bad condition) 5. See if there is a Longines equivalent and either use that, or transplant the bearings from that bridge to the Record. Any help identifying the Longines equivalent (if it exists) would be appreciated. Any suggestions on the alternatives I have discussed are also welcome
    • Really you paid that little for a legit Trupoise?
