I bought this Elco as a donor for a Helvetia 837, decided later that I would have to rebuild it as it has such a beautiful dial.
Having rebuilt it I find that I am getting a kickback on the second hand when winding the hand backwards, I have looked over twice but can not figure out what I must have got wrong. Anyone any ideas?
Cannon pinion too tight?  Does it feel stiff to set the time?  Check the wear on the train wheels, possibly the 4th wheel to the escape, if there is a lot of play between those two then the slack will be transmitted to the center seconds pinion (or whichever wheel drives the seconds pinion in that movement).
Thank AshF & Ww, the hands move quite freely so doesn’t look like the cannon pinion, I’ll open it up this week and check for play in the wheels, hopefully it is a wheel, the3rd & 4th wheel for example are stocked by Cousins, if it’s a jewel then it’s too technical for me.
The movement by the way is a H837, according to the serial number it’s dated 1953.
Graham
