The screw was stuck in thus pocket watch arbor. Despite leaving it to soak WD40, I managed to shear off the screwhead. Is this the sort of thing alum would be good for?
Also, any idea which movement this is? - it is marked as ASSA on the mainplate and the only number is a 2 stamped somewhere else. I understand that ASSA is the same as A Schild (AS) but there is no movement number 2 showing up on Ranftt.
Edited by Bonzer
spelling correction
  • Bonzer changed the title to Removing stuck screw in barrel arbor
Hi  Alum will be a non starter as it eats steel alternatives are a new arbour or drill it out, or use a screw extractor.
some of these screws are LH thread.    attached is the screw extractor. As for finding the details of the watch try pocket watch database. Mikrolisk which gives makers mark info.  cheers
Thanks, I didn't realize these screws can be LH thread too ?
Mikrolisk confirms that ASSA is A Schild. I just need to identify the movement now. Thanks
I've since managed to extract this screw. What are my chances of obtaining a replacement, do you think?
The screw head is 3.4mm dia
Thread LH 0.95mm dia, 1.5mm long
Is there a supplier that would be able to help?
Thank you jdm. I was aware that Cousins sold an assortment but I wasn't sure if it might be possible to order specific sizes from somewhere - although I can see why materials houses would perhaps prefer to sell an assortment.
Thanks for the links ?
It's extenuating to try to buy a single screw, which is then paid a lot more per unit, heaven forbids one breaks or lose it again. What we could do is to buy or sort some assortments individually and then sharing on a running thread what is available for free to other members. I will begin with Seiko 7S, and Swiss setting lever screws, hope someone else will follow.
