Hi all,
complete noob here and just started my watch repairing/fixing journey. I have search the forum and online, but I’m struggling to find the information I need. I am currently working on fixing an old oris watch that was my grandads. Unfortunately for me the pinion on the third wheel went flying from my tweezers. I have had a good look, but it’s gone.
my question is, how do I know I’m ordering the correct size ? Any help would be really appreciated
thank you
Hello and welcome to the forum. I don't want to appear unfriendly, but it's appreciated If you introduce yourself first, and then post in the correct section.
You need to identify the movement. There will likely be a number and a trademark symbol to be found somewhere, usually under the balance.
50 minutes ago, Goublin said:
Hi all,
thank you
It would be nice for you to introduce yourself first, however to address your current issue you need to identify the caliber of the movement then you might be fortunate in finding a replacement in a material house such as Cousins.
You can't miss the Oris branding and caliber on barrel bridge of all in-house vintage movements.
Oris later used Asian made movements which were branded for Oris.
A picture of the bridge layout helps identify the movement.
And Welcome to the forum.
Hi As the guys have said  pictures of the movement front and back with no cover , caliber number and makers name are always useful hen asking questions  attached a list of some of the more common makers.
    • I put the original broken glass (whats left of it) behind the acrylic. This is how it originally looked like. A cheap clock but I like it. Very noisy when the alarm comes wake up guaranteed! 🙂
    • Update!  I've dismantled it, cleaned all the glue off, and rebuilt and lubricated the base movement. I'll leave the chrono part for another day. It's running well - great amplitude and keeping time, but it's got a beat error of 4.8ms.    How important is it to correct this? I'm worried that the potential for making things worse having to take the hairspring off and on repeatedly to adjust this. Would anyone here accept it at that?
