ETA 2836-2 Service Walkthrough
1 hour ago, Klassiker said:
Use the widest screwdriver which doesn't overhang the ends of the screw slot. Stone the width of the taper so that it wedges deep into the slot without touching the bottom. Hold the screwdriver vertically, push down very firmly, and twist anticlockwise.
If you do the above, the tip will not slip.
The best and most concise description ever written of how it should be done! 👍
This is what it should look like.
Edited by VWatchie
  • Thanks 2
On 4/20/2021 at 5:07 PM, VWatchie said:
wonderful explanation sir , thank you for sharing this in images form to make us understand very well in more understandable way to be cleared how thats work on movement's, great work sir 🫡
34 minutes ago, rossjackson01 said:
VWatchie
Really excellent informational image and instruction. Visual is so much easier to follow.
Do you have a database of your lessons. Would you allow purchase as a set?
Thank you
Ross
Yey Ross you're  back, where the hell have you been my man ? I've missed you and was concerned and so were others. How are you matey ?
Absolutely brilliant explanation H, the photo describes it perfectly.
Thanks for your kind words, Ross! Much appreciated and it's great to see you around again! 👍
I'm afraid not and even if I had, I would happily share it with you for free. Some time ago I made a compilation of my walkthroughs here on WRT and you'll find it by clicking here.
I have the unedited pictures for other calibres (listed below) that I plan to create walkthroughs for but we'll see when and if I get around to it. If I do I'll let you know.
AS 1203,
ETA 1080, 2763,
Omega 601,
Peseux 7040,
Raketa 2609.HA, 2623.H,
Rolex 3135,
Seiko 7s36B,
Sellita SW 200-1,
Unitas 6498,
Vostok 2414, 2416B
I couldn't agree more but I'm afraid my only contribution was the picture. The explanation was made by @Klassiker
On 5/29/2023 at 3:00 PM, mikepilk said:
Kalle shows it in a new video (at 57:22)
I was about to show this to someone, but it turns out Kalle has decided his content is now a Netflix-style subscription service. Can’t say I’m thrilled.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
