I recently bought a Steel Dive automatic watch.  This is a Chinese N35-A based Seiko "homage" watch.  When I shook the watch, the counter-weight felt "muffled." Also the TimeGrapher was kind of all over the place.  So I opened it up and found two silicone gaskets (!?) -- also, a bit of vegetable matter (stem of a dried leaf?) fell out when I had the watch open.
I blew it out, dabbed at the weight with some Rodico to clean things up, and re-lubed the larger of the two gaskets.  It now has a +4s reading on the TimeGrapher with an acceptable amplitude.
The main concern I have is what I have done to the watch's water resistance (I don't have -- or have access to -- a hydrotester). So I am starting with the obvious:  Anyone have experience with a two-gasket watch?  Maybe I got a Friday-afternoon special (or a lunch time special)?  I won't ask about vegetable matter. ? That falls into the "you get what you pay for" category at some level.  I can't imagine why a watch maker would use two gaskets where one would do . . .
-Ben
Just a bit of a thread bump.  Some more poking at the bits has revealed the purpose of the second O-ring.  The first one sits in a channel in the case, kind of where I would expect an O-ring seal to be.  The second seems to want to go around the case back -- that is, attached to the case back before you screw the thing on.  Seems like someone was a bit nervous about the ability of the inner O-ring's ability to keep moisture out.  I re-lubed both, torqued the case back on nice and tight and am going to stop thinking about it.  BTW, the thing has been running well for the past several days, but really torquing the case back down seems to introduce some timing error.   Like +4 s/day with the case back off; +30 s/day with the case back on.  ???  Anyone think that simply  torquing down a case back should change the beat rate?  Am I distorting the case when I do so?
I think that if you  had posted some pictures that would have helped others understand the case at hand.
LOL.  No doubt.  Actually, I didn't discover the second O-ring until I gave the open watch a shake to see why the rotor felt so sluggish.  The second O-ring fell on the floor at my feet, along with a small, dry stem of vegetable matter with a bit of leaf still attached.  No idea where in the watch they were originally, because I wasn't expecting to find either.
    • That’s a nice idea, But i’m committed to providing this site as a gift to the watch repair community as my thank you for my incredible life i’ve had in this business. Ive done well and unless my financial circumstances change then i’m more than happy to foot the bill. If circumstances do change then be assured that I will make an appeal. For now, I’m comfortable with the way things are and I am extremely delighted to remove Google Ads from this site and to stop Patreon, it feels like a major step forward 🙂 Sorry, I missed your reply, I got blinded by another poster in this thread. Yes - I can confirm that I have always seen WRT as a not-for-profit website, and therefore - not a business as such. I’m lucky and have done well in my life due to a decision made in my teens to start a watch repairing apprenticeship which has sustained myself and my family for many years now. Consider this my small way of paying it forward. Ive been committed to keeping the site alive on a technical and financial level for over 10 years now and I have zero plans to change that. Thank you for your kind words by the way. And as for your wish - nobody can control what happens in life, if something happens to me I have things in place with my family but I’m just not comfortable talking about my personal business - I wish a certain person would respect that, but i’ve calmed down now - i’m only human 😄
    • Yes, exactly. I've seen a few different versions, but mine has the blue water symbol, not white.    I think it's Acrylic. The case is plastic so I would the is the lens would be too.
    • Hi there Josh, welcome to the forum.
    • From the same listing, the back side: I would guess that the back pops off rather than the front. You can see a little groove there where the caseback sits over the winding stem, rather than a case tube. Look for an indent or notch around the back. It might be possible to pry this off from almost anywhere on the back if it sits right against the rubber strap. The movement looks like it is from the Ronda RL family (015 or 115 or something? I forget which numbers have a calendar and which don't)
    • I'd expect a similar notch somewhere around the rear to pop that off.
