So, I know this is a total newb question, but I am a total newb, so here goes...
There you are at an estate sale and you want to pick up some inexpensive mechanical
watches to learn on, how do you know for sure it's mechanical, without taking the
back off?  Obviously, if it says "Quartz" on the dial it's electric, but will it always  say that?
Any other give-aways?
Thanks for the time!
Hi Tom,
If it's a runner and has a seconds hand check that. If the seconds hands jumps from second to second it's a quartz watch. If it is sweeping from second to second with barely noticible interuptions it's mechanical. In the unlikely event that it's electrical and has yet a sweep second: buy it. It's most likely a pre-quartz tuning fork watch and a collectors item.
Cheers and all the best from Hamburg
Alex
Electric (battery driven spring oscillator) and quartz watches were a big thing when introduced, so they usually advertise this on the dial.
Also, while technically quartz are battery powered and thus electric, if you see "electric" or "electronic" on the dial it's very likely one of a number of battery powered, balance wheel designs. For this reason quartz watches are usually not referred to as "electric"
https://en.wikipedia.org/wiki/Electric_watch
My quick-glance go-to is to look at the crown. Aside from Seiko 5s from a fews years ago and back (which are obvious in their own right), all mechanical movements I'm aware of (even automatics) can be hand wound. In order to be able to be wound, the crown has to be large and knurled enough to do so. Quartz watch crowns are intended to be used a few times a year, and only for setting, so they're almost universally smaller and not very knurled. Mechanical watch crowns [i]can[/i] be very small and smooth if they're super worn, but they'd likely also be badly brassed to go with the wear, and be obvious that way. There can absolutely be overwrought quartz watches with big crowns to look like they're mechanical, but typically they'll be pretty obviously chitzy and give themselves away that way.
    • That’s a nice idea, But i’m committed to providing this site as a gift to the watch repair community as my thank you for my incredible life i’ve had in this business. Ive done well and unless my financial circumstances change then i’m more than happy to foot the bill. If circumstances do change then be assured that I will make an appeal. For now, I’m comfortable with the way things are and I am extremely delighted to remove Google Ads from this site and to stop Patreon, it feels like a major step forward 🙂 Sorry, I missed your reply, I got blinded by another poster in this thread. Yes - I can confirm that I have always seen WRT as a not-for-profit website, and therefore - not a business as such. I’m lucky and have done well in my life due to a decision made in my teens to start a watch repairing apprenticeship which has sustained myself and my family for many years now. Consider this my small way of paying it forward. Ive been committed to keeping the site alive on a technical and financial level for over 10 years now and I have zero plans to change that. Thank you for your kind words by the way. And as for your wish - nobody can control what happens in life, if something happens to me I have things in place with my family but I’m just not comfortable talking about my personal business - I wish a certain person would respect that, but i’ve calmed down now - i’m only human 😄
    • Yes, exactly. I've seen a few different versions, but mine has the blue water symbol, not white.    I think it's Acrylic. The case is plastic so I would the is the lens would be too.
    • Hi there Josh, welcome to the forum.
    • From the same listing, the back side: I would guess that the back pops off rather than the front. You can see a little groove there where the caseback sits over the winding stem, rather than a case tube. Look for an indent or notch around the back. It might be possible to pry this off from almost anywhere on the back if it sits right against the rubber strap. The movement looks like it is from the Ronda RL family (015 or 115 or something? I forget which numbers have a calendar and which don't)
    • I'd expect a similar notch somewhere around the rear to pop that off.
