Hi everyone and hope everyone is OK. bought this watch in a joblot for a tenner (£10.00) so no complaints. The watch works fine but the date changes an hour forward every 24 hours. So if I cycle through the watch and it changes at 12, the next cycle it will be 1am, the next 2am etc. I also removed the hands, cycled the watch to the precise time of date change and then replaced the hands at the 12 O'clock position but the date started to change at the half past position with the same problem as above. The hands sit fine and are snug. Any ideas on what is going on? Many thanks and kind regards.
Pedro.
Just so I understand clearly first it's an hour off then you reposition the hands it's one half hour off?
As it's the calendar parts shall have to take the hands and dial off and see what's going on.
Then it's hard to go beyond this because which movement is this? But we could guess if the hands are actually tracking it's probably not a Canon opinion the problem perhaps. That takes us back to something to do with the the calendar parts which are under the dial unfortunately. Then we can't even look for a tech sheet if one even exists without a movement identification. But more likely have the watch hasn't been serviced in a long time that needs to be done.
Sounds like an interesting symtom, is it falling exactly 1 hour behind with every daychange or what?
A guess with that day date 70's model it would house an 718 movement.
Hi, yes it is a 718 movement. Never come across this problem before. The watch is keeping great time but every day the date change changes an hour forward so one day will change at say 1am, the next 2am and so forth
Had to take a look how one of these loooked like, just happened to have a ORIS Twin Date lying around.
The day date share the same disk for the day date change which is driven through some gears by the hour wheel.
The hour wheel as you know is driven by the small pinion on the minute wheel, and the minute wheel is driven by the cannon pinion. This configuration should ensure the change of time and date to be synchronised by the time.
So if the day date would be affected by the cannon pinion I would expect the time to be off too (check if the time slipps too). So if the time isn't affected this leaves us to the day and date disks, they either got loose from their gears or the day date jumpers are not correctly aligned.
Edited by HSL
Cheers, the movement you have posted is identical to mine. As I am writing this the watch is still keeping excellent time but will keep an eye on it. Will have a look tomorrow and keep you posted, many thanks for your time, effort and advice, it is much appreciated.
Kind regards
Pedro.
    • Hello and welcome from Leeds, England.  Photos please.
    • This is the old/first(?) way for making a mainspring for an automatic. "Evolution-wise" it is an logical first step forward from a standard spring. Usually these are indeed replaced with a new spring with an integrated/fixed bridle. Lubrication as you would do with any automatic.
    • Thank you. I was informed it was a cheap worthless Lack watch from India. It’s in a small mens watch looks to be around 1930 odd   Cleaned the movement and it’s going really well. Keeps good time.  This is a great site. Mystery solved. I’m obliged.
    • I'm working on a Schild AS 1250 (a 'bumper' automatic) and it's the first time I've seen a mainspring like this. It has what looks like a regular manual-wind mainspring with a 'hook' at its outer extremity. On a manual-wind watch that 'hook' would engage with a 'hook' in the barrel wall to prevent it from rotating. However, the AS 1250's mainspring does not engage directly with the barrel but rather with a 'sliding bridle' that sits between the mainspring and the barrel wall, and evidently facilitates the slip necessary in an automatic. I'm not sure what advantage this two-piece configuration provides, but it highlights a gap (one of many) in my horological knowledge. I'm not sure if 'hook' is the correct term as used above, but please see photo below to see what I mean. Therefore, two questions please. 1. What is the proper way to lubricate a barrel from an automatic watch with a sliding bridle? My guess is the same as any automatic ms/barrel (e.g, a few dabs of braking grease on the interior barrel wall). What do the experts say? 2. I purchased a Generale Ressorts GR3472X mainspring, made for the AS 1250. It looks like the bridle is included and I don't need to salvage and re-use the old one. Is this a safe assumption? Thanks for the advice. If you have any other wisdom you'd like to share about separate sliding mainspring bridles, I would be very interested. Cheers!
