This is another Vulcain Cricket I picked up.  The clutch it rusted and bound to the stem.
I have been soaking it in WD-40 for 24 hours.  No luck.  Have pushed, pulled, tapped with a screwdriver--does not budge.
I am willing to sacrifice the clutch.  I want the stem intact, however.  The plate along with all of the other parts removed are donor parts.  But, I do not know how I would be able to cut the clutch without damaging the stem.
The gold crown is necessary for the Vulcain I am rebuilding where I have a good crown and stem, but the crown is white and as far as I can tell, the stem and crown are a unit and thus inseparable.  If anyone knows otherwise, please tell.
Any other chemicals I can use to soak?  I have, in the past, received lots of ideas here about removing a rusty screw using things like alum, coke, etc. This situation is a little different.
In your first picture, I can see the stem end sticking out so punch the stem out by punching on the stem end. Soaking in Cocacola for 30hrs helps.
Good luck pal.
Good luck pal.
I have applied considerable pressure from several directions--afraid to apply any more for fear of breaking, but I will try the coke idea!
There are a bunch of commercial rust removers and they all use some kind of acidic ingredient to convert the rust ( Fe2O3 not to confuse with Fe3O4 which actually protects the steel, bluening) .
A while ago I stumbled up on this tips and tricks from WD40 whom too had a bunch of solutions. https://wd40.co.uk/tips-and-tricks/how-to-remove-rust/
Citric, Oxalic acid and the nasty phosphoric acid are common ingredients in the commercial products too. Guess the acidity is why coca cola might work in the long run too.
Pressure wont work, impact will, punching delivers impact to the stem.
Its like trying to drive a nail into wood by standing on the nail top, you are apllying presuuure? wont do much good, whereas a hammer delivers impact, doesn't have to be strong, many small impacts works like your impact wrench, here you tap on the stem with the punch, many taps.
Regs
Joe
Yes, its the phosparic acid in coke and wont hurt the base metal either. Citric acid will.
Regs
Joe
Sure, I get that.  I tried this by putting the screwdriver blade into the clutch slot and tapping it with a hammer.  It is tough to get a good angle.  I will use a staking tool and see if I can punch from the pin side of the stem.
OK, @Nucejoewins the day.  After his encouragement, I decided to try pounding away again.  However this time, I held everything in place and had my wife swinging the hammer.  It worked.  It was scary.
Here is the watch.  The pusher is from the donor and SS instead of gold.  I still have to solve that.
They are one piece.  It is confirmed.
There is a good reason, too.  In one direction the crown winds the timing spring while in the other it winds the alarm spring.
    • Hello and welcome from Leeds, England.  Photos please.
    • This is the old/first(?) way for making a mainspring for an automatic. "Evolution-wise" it is an logical first step forward from a standard spring. Usually these are indeed replaced with a new spring with an integrated/fixed bridle. Lubrication as you would do with any automatic.
    • Thank you. I was informed it was a cheap worthless Lack watch from India. It’s in a small mens watch looks to be around 1930 odd   Cleaned the movement and it’s going really well. Keeps good time.  This is a great site. Mystery solved. I’m obliged.
    • I'm working on a Schild AS 1250 (a 'bumper' automatic) and it's the first time I've seen a mainspring like this. It has what looks like a regular manual-wind mainspring with a 'hook' at its outer extremity. On a manual-wind watch that 'hook' would engage with a 'hook' in the barrel wall to prevent it from rotating. However, the AS 1250's mainspring does not engage directly with the barrel but rather with a 'sliding bridle' that sits between the mainspring and the barrel wall, and evidently facilitates the slip necessary in an automatic. I'm not sure what advantage this two-piece configuration provides, but it highlights a gap (one of many) in my horological knowledge. I'm not sure if 'hook' is the correct term as used above, but please see photo below to see what I mean. Therefore, two questions please. 1. What is the proper way to lubricate a barrel from an automatic watch with a sliding bridle? My guess is the same as any automatic ms/barrel (e.g, a few dabs of braking grease on the interior barrel wall). What do the experts say? 2. I purchased a Generale Ressorts GR3472X mainspring, made for the AS 1250. It looks like the bridle is included and I don't need to salvage and re-use the old one. Is this a safe assumption? Thanks for the advice. If you have any other wisdom you'd like to share about separate sliding mainspring bridles, I would be very interested. Cheers!
