26 minutes ago, Plato said:
Give it time (pun intended!) I've noticed that the most common profession on here and the BHI is Electrical/Electronics Engineering so it might be an outdated generalisation?
maybe it is a current generation is more acceptable thing. With all their electronic gadgets they can't leave the house without having something that's running on a battery.
But I do remember when I joined the national Association of watch and clock collectors. a lot of times I would avoid if people asked what I collected I'd say pocket watches. But from time to time to have fun I would say I collect quartz watches it was always interesting to see their reaction.
but this was a big Association at slowly shrinking. Which meant that there used to be I think two chapters that weren't electric timepieces. They even organized one of the national meetings in Chicago where the theme was electric timepieces. this is where I met Peter before he published his book he was still doing research.
One simple feature of the Witschi and perhaps others is the glass/mirror viewer.  When I am working on a quartz watch, I find myself flipping the watch over testing for activity and (in the case of Timex) the indiglo function.
On 9/12/2021 at 1:43 PM, LittleWatchShop said:
, can you post some closeup images of the Witschi probe receptacle?
to be honest I never really looked at them and having looked at them it's quite a clever design.
If you look at the jacks found on the device they look innocent enough? Also photographed the end of the wire lead and the base of the wire probe we can see an initial of who made them and what the plug looks like. So this all looks pretty simple and straightforward kinda like a weird version of banana jack.  I suspect all of this was commercially made by somebody else and there is the link to what they look like.
https://www.jewelerssupplies.com/product9694.html
then for the probes you asked about their quite clever. The steel parts goes into the Jack and somewhere in there are springs to hold it in place. This is what's used to set your height adjustment. Then the arms carefully machines to hold the other part of the arm so it can rotate and still have contact. then the very end of the gold probe the little tip is spring-loaded.
On 9/6/2021 at 9:22 PM, LittleWatchShop said:
Most people I know either wear an apple watch or no watch at all.
Yes, it is a sad, sad world... 😟
And how can a wrist computer be called a watch? IMO, that is a prime example of false advertising. It should be prosecuted.
Great pictures @JohnR725.  Exactly what I wanted.
This is a very clever design for sure.  The "banana" like plugs are still a mystery as most banana plugs are closed at the bottom.
The way the pogo pins are mounted on the slotted arm is  a good way to keep pressure on the tube for electrical contact.  This will be hard to copy but I will continue to ponder.  I have ordered some pogo pins to experiment with.
  • jdm pinned this topic
  • 3 months later...
21 minutes ago, jdm said:
hat is the "proper" line release box, it may have additional functions
Interesting...so it can test crystals?  Who does that?  It would be easy to make a crystal tester (for functionality...not accuracy) with a hex inverter, a couple of caps, a diode and LED.
2021-12-21 06_32_05-Amazon.com_ Jewellers Tools 4 in 1 Quartz Watch Tester Release Cell Circuit Test.png
Edited by LittleWatchShop
I have a bit of a problem imagining the average "quartz watch repairer" going to desolder the crystal, test it there and make progress from the result.
On the other hand probably the ideal all-in-one quartz tester doesn't exist. Various types have been presented and discussed in other topics. In the end I think everyone does according to his needs, aspirations, and budget.
  • 7 months later...
By the way, I see quartz adjustments all the time on Spencer Klein's channel. He specializes in Seiko servicing, and he uses the Seiko QT-99 quartz tester that someone linked above. He adjusts lots of the Arnie divers from the 1980s using that tester, typically getting them down to a quarter second per day or less. Here's an example.
I don't know if those kind of adjustable movements are still used – those were H558 and H556.
That Seiko QT-99 tester was released in the 1970s. In the 1990s Seiko followed up with the QT-2xxx series with higher resolution (models were something like 2400, 2500, 2600). I think the difference was going from hundredths of a second with the QT-99 to better than milliseconds with the 2xxx models. It was all about the frequency of the oscillators in the testers. I don't know how they worked though – mechanical watch timing machines are acoustic, with microphones, but I'm not sure what the mechanism is with quartz watch timing machines (I don't think the cheap stuff cited on this thread are timing machines, just juice testers).
On 9/6/2021 at 12:22 PM, LittleWatchShop said:
In the US, I can write off a capital cost in one tax year, so if I spent the 2.5k, the fed would subsidize roughly 30%, so my out of pocket is more like 1.75k.
I get so confused by the way people talk about tax deductions and "write-offs".
You're not getting any of that money back. It's not a tax credit. If you spend money on equipment, that money is gone, as is the case when you spend money on almost anything. Writing it off just means you get to treat it as a business cost, but I don't know why we wouldn't start with the assumption that anything we spend on a business is a business cost – why wouldn't we be able to treat it as such? All it does is feed into your profit/loss calculation, reducing your taxable profit, which is the nature of a business expense.
The previous poster said it could be amortized as though this was a good thing – that just means you don't get to write off the full expense in the year you incurred it, which is a bad thing. It means that you could actually lose money in that year, but you would be taxed on "profit" that didn't exist because you weren't allowed to write off your purchase of, say, a Witschi. This is partially offset by amortized deductions in subsequent years – years where you don't have that purchase expense – but it drags out the write-off, which creates additional expenses and cash requirements.
If you buy a Witschi the only way to get the money "back" is with any revenue it generates. No government gives you that money back. It's a cost like benches and loupes and ultrasound, and you get to treat it as such in profit calculations, but your out-of-pocket is 100%.
  • Mark unpinned this topic
  • Mark pinned, unpinned and featured this topic
  • Similar Content
    • Why now Mark ?  And which contact has brought you here ? People have been trying for bloody months to get hold of you for reassurance. Shite way to run a forum tbh. Seven months since you last visited. I think we all need to have a long discussion with you about what happens if anything happens to you. Please look forward to lots of questions.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
