Probe Set
AshF
So you know when you're opening shock springs and you use one prong of your tweezers but then sometimes the other prong gets in the way.  Plastic probes are too soft for this job so I've been looking for a metal one.  I've been looking on Cousins website for ages (one of my favorite pastimes) but never saw anything suitable.  I was going to snap some old tweezers in half but then happened to look in the "Dental Tools" section and found these.
https://www.cousinsuk.com/product/probe-set
£2.15, worth a punt don't you think?
11 hours ago, AshF said:
I also suspect that @HectorLooiuses these very tools for dentistry!
Good gracious! NO! ?
Those are from India. I've bought some before many years ago from an electronic hobbyist supply store for cleaning up circuit boards after etching in ferric chloride. The quality is horrendous. The tips are as thick as knitting needles and they RUST!
I use a broken oiler for opening shock springs. I also made my own tool by sticking a sewing needle into the end of a bamboo chopstick. But remember to cap them because they have a habit of stabbing you when you're rummaging for stuff on your bench.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
