My father in law asked me to look at his watch which uses a Harley Ronda HQ515.24H movement.
https://www.esslinger.com/harley-ronda-quartz-watch-movement-hq515-24h-24-hour-date-at-3-00-overall-height-4-8mm/
Starting with the simplest thing, I assumed the battery was dead.  I didn't have a spare 371 battery so I used my bench power supply.  I touched the positive lead to the top plate that makes contact with the positive side of the battery, and the negative lead to the plate on the bottom of the battery compartment, and the watch started to tick.  I ordered a replacement battery, and put it in, but the watch doesn't tick.  What else might be going wrong that is stopping it from working?
Edited by GregG
When working on electrical stuff assuming is not a good word indeed test equipment. Like a digital volt meter was the battery good or bad? A good battery indicates a watch problem a bad battery indicates it's probably the battery but not 100%.
Then just to clarify your telling us it works fine with your power supply but does not work with the battery?
I'm assuming you did test the voltage of the new battery to make sure it actually is a new battery? Then there's an insulator under the battery is that still there?
Then I be helpful to give us pictures so we can see the watch and see if we see a problem.
Then I've attached the technical documentation just in case you didn't have
Datasheet_515_24H_Complete_technical_documentation.pdf
Ahhhh, interesting, I don't have part # 3603.034.  I'm assuming 3601.078 is what's supposed to actually make contact with the negative side of the battery?
I've verified that the old battery is dead, and the new battery is good.  And yes you are correct it works with the power supply, but not with the battery.
Edited by GregG
Yes the pictures shows your definitely missing the insulator. Without that in place as soon as you put the battery in it short salad and the watch definitely will not run. They need a thin piece of plastic to put under their otherwise it's a new movement. As I don't know what it would cost to buy a new insulator although sometimes you by those in assortments. But as soon as you have to put any money into parts it's cheaper just to buy the movement.
Thanks. Would it be possible to just stick a piece of electrical tape under the gold contact finger and on top of the base plate?
Yes you could. Kapton tape would even be better.
If it still doesn't work, check the current consumption of the movement. It might be so gummed up that the battery cannot supply enough current move the wheels.
In that case, you'll have to clean and lubricate the movement.
It definitely won't run if the battery is short of salad!!!!!!  ???
<My apologies @JohnR725 I couldn't resist>
  • Haha 2
It's probably fine but I wouldn't use electrical tape, with age the adhesive leaves a mess. For this situation I've just cut out a small disc of thin plastic, like from a thicker bag, or those clear plastic clamshell packages that everything comes in these days.
    • This is the old/first(?) way for making a mainspring for an automatic. "Evolution-wise" it is an logical first step forward from a standard spring. Usually these are indeed replaced with a new spring with an integrated/fixed bridle. Lubrication as you would do with any automatic.
    • I'm working on a Schild AS 1250 (a 'bumper' automatic) and it's the first time I've seen a mainspring like this. It has what looks like a regular manual-wind mainspring with a 'hook' at its outer extremity. On a manual-wind watch that 'hook' would engage with a 'hook' in the barrel wall to prevent it from rotating. However, the AS 1250's mainspring does not engage directly with the barrel but rather with a 'sliding bridle' that sits between the mainspring and the barrel wall, and evidently facilitates the slip necessary in an automatic. I'm not sure what advantage this two-piece configuration provides, but it highlights a gap (one of many) in my horological knowledge. I'm not sure if 'hook' is the correct term as used above, but please see photo below to see what I mean. Therefore, two questions please. 1. What is the proper way to lubricate a barrel from an automatic watch with a sliding bridle? My guess is the same as any automatic ms/barrel (e.g, a few dabs of braking grease on the interior barrel wall). What do the experts say? 2. I purchased a Generale Ressorts GR3472X mainspring, made for the AS 1250. It looks like the bridle is included and I don't need to salvage and re-use the old one. Is this a safe assumption? Thanks for the advice. If you have any other wisdom you'd like to share about separate sliding mainspring bridles, I would be very interested. Cheers!
    • Thank you Hector. You too matey 😊
    • Bless you, Mark. May you live long and prosper!
    • That’s a nice idea, But i’m committed to providing this site as a gift to the watch repair community as my thank you for my incredible life i’ve had in this business. Ive done well and unless my financial circumstances change then i’m more than happy to foot the bill. If circumstances do change then be assured that I will make an appeal. For now, I’m comfortable with the way things are and I am extremely delighted to remove Google Ads from this site and to stop Patreon, it feels like a major step forward 🙂 Sorry, I missed your reply, I got blinded by another poster in this thread. Yes - I can confirm that I have always seen WRT as a not-for-profit website, and therefore - not a business as such. I’m lucky and have done well in my life due to a decision made in my teens to start a watch repairing apprenticeship which has sustained myself and my family for many years now. Consider this my small way of paying it forward. Ive been committed to keeping the site alive on a technical and financial level for over 10 years now and I have zero plans to change that. Thank you for your kind words by the way. And as for your wish - nobody can control what happens in life, if something happens to me I have things in place with my family but I’m just not comfortable talking about my personal business - I wish a certain person would respect that, but i’ve calmed down now - i’m only human 😄
