Hi guys,
I am trying to replace the movement in my Seiko SNZF17J1 which has 7S36 movement with NH36 movement. First, this is my first attempt doing this since I had damaged the movement while regulating it. I figured since the 7S36 is a non-hacking movement, I might as well replace it with NH36. Before I embark on the process I would like to know what are the things that I need to be prepared for. First I know that I need to change the date wheel since my watch has black date wheel while the NH36 movement I bought is white. I think I can do this part which I have seen the video on youtube. I have also bought a few tools with me such as watch repair set screwdrivers, watch movement holder, tool set remover, hand pressing tools, case opener and may buy more tools as needed here. If you can suggest what other tools I need, please let me know here.
A few questions here:
1) Do I need to change the dial spacer from the old movement?
2) Is the stem different from the 7S36 to the NH36?
3) When installing second hand, is it better to install when the watch is in stop position? I have seen people installing it while it is engaged/moving.
Thanks in advance and looking forward to hear from you all watch hobbyists!!
1) I think what you're calling the dial spacer doubles as a movement spacer here. I believe they're interchangeable from the movement's perspective, but potentially not as much from the case's perspective. To wit, I have an NH39 that I'm confident will be a **BLEEP** and a half to extract from the case when I eventually need to do so.
2) Yes. You'll need to cut the new stem to fit the case, clean up the threads, apply some loctite, then install your crown.
3) It doesn't hurt, probably better if you do, but it's not strictly necessary.
Not unless you're swapping from/to a diver watch, to a non diver. The spare ring on the latter is marginally thinner.
Quote
Yes.
Quote
Yes, as that tell syou it's straight on, and ready to be pressed down.
    • Hello and welcome from Leeds, England.  Photos please.
    • This is the old/first(?) way for making a mainspring for an automatic. "Evolution-wise" it is an logical first step forward from a standard spring. Usually these are indeed replaced with a new spring with an integrated/fixed bridle. Lubrication as you would do with any automatic.
    • Thank you. I was informed it was a cheap worthless Lack watch from India. It’s in a small mens watch looks to be around 1930 odd   Cleaned the movement and it’s going really well. Keeps good time.  This is a great site. Mystery solved. I’m obliged.
    • I'm working on a Schild AS 1250 (a 'bumper' automatic) and it's the first time I've seen a mainspring like this. It has what looks like a regular manual-wind mainspring with a 'hook' at its outer extremity. On a manual-wind watch that 'hook' would engage with a 'hook' in the barrel wall to prevent it from rotating. However, the AS 1250's mainspring does not engage directly with the barrel but rather with a 'sliding bridle' that sits between the mainspring and the barrel wall, and evidently facilitates the slip necessary in an automatic. I'm not sure what advantage this two-piece configuration provides, but it highlights a gap (one of many) in my horological knowledge. I'm not sure if 'hook' is the correct term as used above, but please see photo below to see what I mean. Therefore, two questions please. 1. What is the proper way to lubricate a barrel from an automatic watch with a sliding bridle? My guess is the same as any automatic ms/barrel (e.g, a few dabs of braking grease on the interior barrel wall). What do the experts say? 2. I purchased a Generale Ressorts GR3472X mainspring, made for the AS 1250. It looks like the bridle is included and I don't need to salvage and re-use the old one. Is this a safe assumption? Thanks for the advice. If you have any other wisdom you'd like to share about separate sliding mainspring bridles, I would be very interested. Cheers!
