Greetings all.
I recently picked up a nice Elgin 18s grade 27 movement. It seems to be a very well made grade, with interesting, probably patented, features. It has some minor oxidation here and there, but seems like it'll be a runner after a basic service. I'm at the point where I'd like to remove the disc shaped gear (Crown wheel? At roughly 12:30 in image.) that meshes with the winding pinion but it is held to the plate by a different sort of fastener. I'm guessing that it threads on and off by using a wide, thin, screwdriver or special tool that I'm without. Is this correct? Does it thread? Is it standard a right-handed threaded part? Any help or tips would be greatly appreciated. Many thanks! Cheers.
So just in case anyone ever runs into this, the fastener certainly does thread on. It is removed with a thin, but broad, screwdriver. The trick is that it has left-handed threads. I asked because I didn't want to force it. Rick H. over at the NAWCC verified that it was indeed threaded. Cheers all.
