This is a strange problem that I've encountered with the IC potting material of Seiko watches.
The 1st photo is a Seiko 1N00. The usual black blob of epoxy or whatever potting material has disintegrated into a sticky, tar like substance. If I were to wash it in plain water, it'll wash away completely, leaving no traces of the IC.
I first encountered this problem while repairing my father's Seiko AGS. It demonstrated intermittent periods of working and periods of shorting out. Seiko had replace the accumulator, generator and pcb many years before but never really resolved the problem.
I tried to repair it last year and found some corrosion of the pcb tracks and some clear, sticky liquid around it. I assumed it was battery electrolyte and soaked the pcb in distilled water. When I fished it out, I was shocked to find that the entire IC disappeared! 😱
I've been searching for a replacement pcb but to no avail.
Have anyone else seen an IC disintegrate?
That's not strange at all. A lot of the materials we generally name as "plastic" degrade even just over a few years. Did the designers knew that they were not to last, or there were variations beteween batches, that's anybody guess.
I was in a class once given by eta and I believe he call that engineered material as opposed plastic. But my memory may be a little fuzzy but I'm pretty sure that's what was called.
The problem is with plastic as noted above it can do all kinds of interesting things with time usually none of which will be good. Plus if any environmental things are there like somebody who insist on cleaning it with solvents are not supposed to. But even without that plastic does have a habit of disintegrating. I have an electric watch around here with green plastic holding the battery and a lot of the components has just disintegrated.
then there may be other things going on like for instance if this is a resin that was mixed what if it didn't get mixed properly?
So if you have a watch that has plastic components you really should stock up on those components and hope they don't fail also.
I have a watch the same as JohnR725 who's geen plastic frame is just about dust, I have had quartz clock movements with the wheels with no teeth at all just a disc, niot all plastics are the same for sure.
6 minutes ago, watchweasol said:
not all plastics are the same for sure.
For sure. In the family we have then-expensive items from the '60s like tape recorders, 8mm projector, picnic set... Time just made the plastic harder. Possibly brittle, but I won't try.
    • Hello and welcome from Leeds, England.  Photos please.
    • This is the old/first(?) way for making a mainspring for an automatic. "Evolution-wise" it is an logical first step forward from a standard spring. Usually these are indeed replaced with a new spring with an integrated/fixed bridle. Lubrication as you would do with any automatic.
    • Thank you. I was informed it was a cheap worthless Lack watch from India. It’s in a small mens watch looks to be around 1930 odd   Cleaned the movement and it’s going really well. Keeps good time.  This is a great site. Mystery solved. I’m obliged.
    • I'm working on a Schild AS 1250 (a 'bumper' automatic) and it's the first time I've seen a mainspring like this. It has what looks like a regular manual-wind mainspring with a 'hook' at its outer extremity. On a manual-wind watch that 'hook' would engage with a 'hook' in the barrel wall to prevent it from rotating. However, the AS 1250's mainspring does not engage directly with the barrel but rather with a 'sliding bridle' that sits between the mainspring and the barrel wall, and evidently facilitates the slip necessary in an automatic. I'm not sure what advantage this two-piece configuration provides, but it highlights a gap (one of many) in my horological knowledge. I'm not sure if 'hook' is the correct term as used above, but please see photo below to see what I mean. Therefore, two questions please. 1. What is the proper way to lubricate a barrel from an automatic watch with a sliding bridle? My guess is the same as any automatic ms/barrel (e.g, a few dabs of braking grease on the interior barrel wall). What do the experts say? 2. I purchased a Generale Ressorts GR3472X mainspring, made for the AS 1250. It looks like the bridle is included and I don't need to salvage and re-use the old one. Is this a safe assumption? Thanks for the advice. If you have any other wisdom you'd like to share about separate sliding mainspring bridles, I would be very interested. Cheers!
