Center wheel pinion detached from center wheel? How to re-attach? Longines Pocketwatch - ca 1920s
Hello, I am a hobbyist and working for sometime now on circa 1920's Longines pocketwatch with 15 jewels movement. I am very determined to bring it back to life and have already overcome a few gotchas, from trivial glass replacement to broken mainspring hook. Just when I have finally put it together after removing 3 broken screws, I was greeted with another surprise: th barrel would just move in either way if I advanced it with a screwdrier ever so gently. Winding up the barrel clicks, but as soon as there is any energy, the barrel just moves around, without hands moving. First I thought that there was a fitment issue. and maybe the barrel did not have proper contact with the pinion of the center wheel, and when I inscpected it closer I found that the pinion just flies around, so if I had an hour hand, I think it would be spinning like in those doomsday movies.
I don't think this was supposed to work like that. Without the pinion and the wheel being coupled, the mainspring cannot hold any energy, so the watch does not run.
Is it even possible to re-solder / re-attach / superglue the pinion and the wheel, so they are fused? If not, how does one go about ordering a new center wheel with pinion for a pocketwatch that is about 100 years old?
Right now I am very tempted to try my battery leads spot welder on that wheel...
Thank you.
Could you post some photo of the parts. Normally they are riveted together by means of a punch from a watchmakers staking set.
Could it be the safety pinion possibly?  I know you mentioned the mainspring hook was broken off.  If that happened while it was wound more than a little, the safety pinion on the center wheel would release or unscrew, so that the instant release of power from the spring doesn't cause a thermonuclear detonation in there.
EDIT: I got to thinking: my Longines is a 1919 18.5 calibre and I don't think it has this feature.  I think only my American pocket watches do. Could you maybe post the size/calibre and some pics.  If it happens to be a safety pinion issue, I might be able to help more also.  But I think O.H. is likely correct about this - if the spring cut loose, then the center wheel pinion likely took the hit.  You may want to look through the going train for other damage.  Pics help loads (that, and I can maybe look up the movement in Ranfft's Bidfun archive).
Edited by KarlvonKoln
edited for clarity
Thank you KarlvonKoln and oldhippy.
Here is a video of the predicament I find myself in.
https://1drv.ms/v/s!ArG5E62RGctxjZs5lRZfnRAz_w3gNg
I really hate this wobbling action. I don't have a stake punch set at my disposal, so am looking for other creative ideas on fix it, or alternative approaches of acquiring a similar center wheel.
And here is the bridge plate with the movement details:
https://1drv.ms/u/s!ArG5E62RGctxjZs4JO-uZJNUAJafJg
Thank you in advance for any insights.
As you don't have a staking set. You could use loctite 680, it is very good to hold a new pivot that has been made for a wheel in a clock.
  • Thanks 2
... And I broke it. Almost fixed it with an improvised stake punch, but the shaft got bent a bit, so as in those videos Mark mentions, I did not get lucky and the bent shaft just snapped.
I have taken dimension of that thing, any ideas on where to source something like this?
Shoudl I buy one of those steampunk "by the weight" sets and hope that I can score something fitting?
I was thinking Loctite until I saw the problem. Normally are a lot of times the rivet is the pinioned leaves coming down on to the brass wheel itself but it looks like for whatever reason it's spinning their and it looks loose enough that I don't think Loctite would hold. If it was just pinion had somehow come off the shaft then the Loctite is great.
it be nice to see a picture of what's left of it? Unfortunately and watch repair we don't have universal parts kind of. So we'll have to see where it's broken I don't suppose you have a watchmaker's lathe?
JohnR725 - thank you. Any recommendations on which lathe I should get? As I mentioned earlier, this Longines WILL TICK AGAIN!
6 hours ago, oldhippy said:
Are you after a watch or clock makers lathe? what is your budget?
Watchmaking would be the main purpose, anything from pivots to arbors, but I often require some work on larger items. Budget-wize, I would prefer to get something under 1K USD.
Have you looked on ebay? If I were you I would look for one that takes 8mm collets. Some like the lathe to be foot controlled (that is what I had) while others prefer direct control and in order to change speed this is done by a way of changing the belts around onto the pulleys.Make sure the bed is in very good condition and the late bed to be true. Would you like me to have a look for you on ebay.  1K USD what is that in english pounds?
Longines came back and identified the movement as 18.79. Ranfft does not have it in their database, so I will post the writeup about the movement here in case others require the info. It is one beautiful caliber.
Caliber_18.79.pdf
  • Thanks 2
Quite beautiful indeed.  Thank you, Dmitry, for posting this information and adding to our collective knowledge.  I have a Longines 18.5 of my own, and am rather fond of it, and I like learning more about them.
For a start have a read below:
  • 4 weeks later...
And the nice 18.79 is now running again!
Scope of changes:
1. Wrong mainspring was installed, the most likely source of why the center wheel got unhinged. Replaced with proper mainspring, which was a bit narrower and less powerful.
2. New center wheel
3. New domed class
4. Snapped screw extraction and replacement on the keyless mechanism
5. A few new screws to replace mismatched in place
6. Complete movement cleaning and service
It is now proudle displayed in my collection.
One question remains, the porcelain dial is unique, back in the day they were personalized. Mine is personalized with likely owner's name, the same name is engraved on the back of the mainplate. The top layer of porcelain has a crack and a chip at 10, any good sources / tutorials on how to fill/fix those cracks?
Edited by Dmitry
I just sold a very nice boley on ebay that had excellent runout (less than 15 microns) for $220.  I kinda developed a lathe fetish and started acquiring them...decided I had too many.  I am sure you can find a nice one for this price range.  The one I sold did not have a motor or stand.  You can get a motor for about $100 or buy a sewing machine motor for even less.
1 hour ago, watchweasol said:
Hi looking at the chip , a care full application of the Milliputty will do the job     https://www.milliput.com/howto.html    This is a how to script to get the best results.
Thank you, what about the ink on the dial? Do I need to sand the dial, apply milliput and then completely recreate the dial with that fansy laser printer decal paper (Mark had a video on a dial restore), or is there a better approach to repair just that part?
Edited by Dmitry
Hi   Normaly use Indian ink for the marking , Milliputty is available through Amazon or Ebay. Got mine from a Hobbies shop.  If you smooth it out thinly using water as a lubricant as per the words there should be little need for sanding if required use very fine paper with water on a Lollypop stick ( Popsickle) as its just a repair be careful.
    • That’s a nice idea, But i’m committed to providing this site as a gift to the watch repair community as my thank you for my incredible life i’ve had in this business. Ive done well and unless my financial circumstances change then i’m more than happy to foot the bill. If circumstances do change then be assured that I will make an appeal. For now, I’m comfortable with the way things are and I am extremely delighted to remove Google Ads from this site and to stop Patreon, it feels like a major step forward 🙂 Sorry, I missed your reply, I got blinded by another poster in this thread. Yes - I can confirm that I have always seen WRT as a not-for-profit website, and therefore - not a business as such. I’m lucky and have done well in my life due to a decision made in my teens to start a watch repairing apprenticeship which has sustained myself and my family for many years now. Consider this my small way of paying it forward. Ive been committed to keeping the site alive on a technical and financial level for over 10 years now and I have zero plans to change that. Thank you for your kind words by the way. And as for your wish - nobody can control what happens in life, if something happens to me I have things in place with my family but I’m just not comfortable talking about my personal business - I wish a certain person would respect that, but i’ve calmed down now - i’m only human 😄
    • Yes, exactly. I've seen a few different versions, but mine has the blue water symbol, not white.    I think it's Acrylic. The case is plastic so I would the is the lens would be too.
    • Hi there Josh, welcome to the forum.
    • From the same listing, the back side: I would guess that the back pops off rather than the front. You can see a little groove there where the caseback sits over the winding stem, rather than a case tube. Look for an indent or notch around the back. It might be possible to pry this off from almost anywhere on the back if it sits right against the rubber strap. The movement looks like it is from the Ronda RL family (015 or 115 or something? I forget which numbers have a calendar and which don't)
    • I'd expect a similar notch somewhere around the rear to pop that off.
