Hello - I hate to be that guy, but I cannot figure out what movement I'm dealing with here. It's in a Baylor watch and has no day/date and has a sweep second hand. There is no makers mark under the balance or elsewhere, including on the dial-side. The lone markings are "Germany" and Baylor Watch Company. I've tried Ranfft's idenfier tool, but no luck (does not appear to be a PUW). It resembles an AS/ST 96, but has differences in the bridges. Ultimately, trying to find a winding stem. Thanks in advance, friends!  -Mike
I agree.  It looks like a variant on the HB 110.  I have a number of HBs.  Mostly the 115s and 120s. Stylistically speaking, it has a lot in common with them too.
Edited by KarlvonKoln
Appreciate the confirmation. Now to track down a stem from cousins... :). Thanks again!
    • This is the old/first(?) way for making a mainspring for an automatic. "Evolution-wise" it is an logical first step forward from a standard spring. Usually these are indeed replaced with a new spring with an integrated/fixed bridle. Lubrication as you would do with any automatic.
    • I'm working on a Schild AS 1250 (a 'bumper' automatic) and it's the first time I've seen a mainspring like this. It has what looks like a regular manual-wind mainspring with a 'hook' at its outer extremity. On a manual-wind watch that 'hook' would engage with a 'hook' in the barrel wall to prevent it from rotating. However, the AS 1250's mainspring does not engage directly with the barrel but rather with a 'sliding bridle' that sits between the mainspring and the barrel wall, and evidently facilitates the slip necessary in an automatic. I'm not sure what advantage this two-piece configuration provides, but it highlights a gap (one of many) in my horological knowledge. I'm not sure if 'hook' is the correct term as used above, but please see photo below to see what I mean. Therefore, two questions please. 1. What is the proper way to lubricate a barrel from an automatic watch with a sliding bridle? My guess is the same as any automatic ms/barrel (e.g, a few dabs of braking grease on the interior barrel wall). What do the experts say? 2. I purchased a Generale Ressorts GR3472X mainspring, made for the AS 1250. It looks like the bridle is included and I don't need to salvage and re-use the old one. Is this a safe assumption? Thanks for the advice. If you have any other wisdom you'd like to share about separate sliding mainspring bridles, I would be very interested. Cheers!
    • Thank you Hector. You too matey 😊
    • Bless you, Mark. May you live long and prosper!
