Hey!
I'm new to watch making. I bought a new seiko SKX007 , and i bought a saphire crystal mod for it. I was installing it, and everything seemed to have worked correctly, but when reassembling the watch, the crown function (rotating, etc) seemed malfunctioning.
Now, when the crown is in the neutral position and i spin it, it makes a sound as if something was moving inside, and effectively it is. A gear is moving when rotating the crown, which can be seen in the video. It wasn't like this before, in the neutral position it would just spin and do nothing until i pulled it to the 2nd (date) or 3rd(time) position.
From what i've read, this might be related to a disloged yoke / keyless works? Any how, i'm not sure how to fix it. I've checked the seiko service guide by watch repair channel but i'm hoping the fix can be done without dissasembling the whole thing.
I would greatly appreciate any help, this is my first "proyect" and i would love to have it done correctly
Your watch has been refitted with an NH35 mov.t, taking the winding weight from an 7S26. Hence it can be manually wound in the first crown position, which an added  feature of the NH35, the other being that it hacks.
Quote
The most likely reason it was not doing that before is because the stem has been cut too short, or the crown spring is a bit too weak, form the stem to positively reach the first position (winding) every time. That is a common occurrence when using a commercialy available stem/crown assembly.
Furthermore, by the way the mov.t moves in the case under the action of the crown, and the color of the spacer ring, it appears that the latter is the one that comes with the NH35, which is not correct for a diver's case. The original spacer ring is a bit taller and holds better.
I really appreciate your time for answering my question. This watch was sold to me as new, should I be concerned about this change of movement? Or would you rather consider it an upgrade?
You should be able to tell a new watch from an even just slightly used one by looking at various small details, as boxing, papers, caseback and bracelet films, hair lines,etc.
Another possibility is that is counterfeit, which would be to expected considering that these went out of production like 2 years ago with demand and prices surging, and 7S26 (NH26) mov.ts aren't available anymore on the OEM market.
Other than that the NH35 is a common and cheap upgrade or repair solution among Seiko owners.
    • This is the old/first(?) way for making a mainspring for an automatic. "Evolution-wise" it is an logical first step forward from a standard spring. Usually these are indeed replaced with a new spring with an integrated/fixed bridle. Lubrication as you would do with any automatic.
    • I'm working on a Schild AS 1250 (a 'bumper' automatic) and it's the first time I've seen a mainspring like this. It has what looks like a regular manual-wind mainspring with a 'hook' at its outer extremity. On a manual-wind watch that 'hook' would engage with a 'hook' in the barrel wall to prevent it from rotating. However, the AS 1250's mainspring does not engage directly with the barrel but rather with a 'sliding bridle' that sits between the mainspring and the barrel wall, and evidently facilitates the slip necessary in an automatic. I'm not sure what advantage this two-piece configuration provides, but it highlights a gap (one of many) in my horological knowledge. I'm not sure if 'hook' is the correct term as used above, but please see photo below to see what I mean. Therefore, two questions please. 1. What is the proper way to lubricate a barrel from an automatic watch with a sliding bridle? My guess is the same as any automatic ms/barrel (e.g, a few dabs of braking grease on the interior barrel wall). What do the experts say? 2. I purchased a Generale Ressorts GR3472X mainspring, made for the AS 1250. It looks like the bridle is included and I don't need to salvage and re-use the old one. Is this a safe assumption? Thanks for the advice. If you have any other wisdom you'd like to share about separate sliding mainspring bridles, I would be very interested. Cheers!
    • Thank you Hector. You too matey 😊
    • Bless you, Mark. May you live long and prosper!
