Certina 25-661 movement - Date driving wheel
Ced
Hello all,
I have been servicing a Certina 25-661 movement. Everything went fine until I reassembled the calendar work.
The movement is running well, the date can be changed manually via the time setting position...but, when letting the movement run, it won't change the date automatically. The tiny teeth of the date driving wheel would push against the teeth of the date wheel, but won't move any further, while the balance wheel is still running.
I wonder whether I missed some proper alignment of the date driving wheel or if there is not enough power/torque coming from the mainspring.
Thank you for letting me know what you think about this issue.
Cedric.
The fact that the watch keeps running whilst the date change remains locked and fails to change would suggest to me that there is a lack of traction or slippage in the calender work, Does the watch continue to work in this condition although the date remains unchanged. I would remove and closely inspect the drive components and check for wear on the points and changer.
If you have a look at the Ranfft site  it will list all the family variants of his movement.
attached is the tech sheet with calender parts should you need it.
1806_Certina 25-65, 25-651, 25-652 (2).pdf
Hello !
I did not think of it that way, thank you for your recommendation and technical information, I will disassemble and scrutinize the calendar work.
To answer your question, once the teeth are in contact, the time stops while the balance continues to run.
On this picture, we can see the date wheel moved slightly, but remains stuck at that point.
Will let you know the outcome,
Thanks again,
Ced.
Alleluia !
Upon close inspection of the calendar work, I could not find any anomalies.
Therefore I replaced the canon pinion with another one coming from a scrap movement.
And yes, it works !
Many thanks !
  • 3 years later...
Hey thanks guys! I have a Gubelin watch with a Gubelin A1022 movement which is a re-branded Certina 25-661 and had a very similar problem.  All seemed fine with the watch until around midnight when the seconds hand would stop and  no date flip over . Scratched my head for days on this problem and then found this posting. Got hold of a spare 25-661 movement and replaced the cannon pinion in the A1022. All is working perfectly today! Many, many thanks again for sharing your expertise and knowledge .
So was the old canon pinion damaged?
2 hours ago, ScottNB said:
didn't look to be damaged, just worn I guess
When the seconds hand stop, its usually either one of these cases,
1- Oscilator stops as well.
2- Oscilator continues oscilating.
 Case No 2 is the most common, which often is a case of loose canon pinion, in which case you don't need a replacement , just tighten the canon pinion.
Case 1,  Usually points to a damaged part, or many other possibilities.
Spotting the fault helps improve diagnostics.
Regs
    • I recently repaired this movement but the screw for the ratchet wheel was the wrong size and it was bugging me (pic 1). I tried to find a replacement but I couldn't match the head width and tap size, so I decided to make one.  I wasn't sure of the tap size for the screw, but it looked to be either 1.0 or 1.2 so I made a test screw out of a brass bar, with a matching threaded hole on the other end. I didn't photograph this but you can see the bar in picture 4. I settled on a size and proceeded to cut a steel bar down to length. I softened the bar first to make it easier to work with and the cut it to size, using the chart on my tap and die set for reference Once cut I set up the die in its holder and used my tailstock to hold it straight while I created the thread. Once the thread was cut, I tested it using the brass bar Happy with the diameter and thread I cut the screw off the bar and then twisted it into the bras bar to use it as a holder,  for securing it in the lathe to protect the thread I made a face cut to clean the head up Next step was to make the slot. I currently do not have a table saw for the lathe so I was going to have to use a saw. To keep the cut straight and centred, I made a jig out of a piece of brass bar by drilling a hole big enough to slot over the stew, with a slot in it to guide the saw while cutting the slot on the screw head I then cut the slot with a fine saw (I forget what they're called, pin saw?). Once that was done, it was ready for hardening and tempering and then a first polish from 800 grits to 2000 on the lathe. The picture below is just before the first polish. Once I got it to polished with 2000 grit, I removed it from the lathe and then polished it with diamond paste and a Dremel, using the brass bar to hold it. (this turned out to be a really useful tool) Finally, it was ready to go into the movement. I am pleased with the result. I should have made it flatter to match the crown wheel screw better but, overall, it is a vast improvement on the screw that was in there. The main thing I took away from this was how useful the brass bar was, not just for testing the thread but as a holder in the lathe, for cutting the slot and for handling when polishing. No trying to hold it with tweezers or a vice. It was a really simple tool to make and really worth the 10 minuets or so to make it and cut the threads. The slot guide was a huge bonus because it worked much better than expected.
    • I finished a couple of pinions I started yesterday, read up on Breguet hairsprings, made a balance staff, fixed my tool and cutter grinder, and in between checked in here. Having a (2rd) pint with the missus now 😍.
    • I must update myself, I guess nowadays the lubrication procedures and assembly protocols have improved or, at least, changed.  I hope there is still hope for vintage tools in this area.
    • Lol ok, well I'm not about to explain it, I'm a bit fuzzy on it myself, I'll get it all arse about face.....actually that might be part of it, now I come to think about it.
