That's a nice movement. Two tips: make sure the shock spring is seated carefully as they can affect amplitude if they cause the jewels to shift in one direction. Check the amount of friction provided by the centre-seconds friction spring is reasonable. Probably such that it knocks around 5-10 degrees of amplitude off the total amplitude when it is not fitted. And also note that they are very fragile and probably made from beryllium.
Yes this is a tricky movement.  The top jewel fell out a couple of times when I had the movement turned over...somehow, the paddle moved and then gravity took over.  What I did was to push the paddle aside so that it was cantilevered and then bend it down.  Hope that does the trick.
Had some odd timing issues on the timing machine.  Not sure yet what to make of it, but it is running nicely face up on the bench.
This uses a two-piece stem.  Unfortunately the crown was broken off (though I still have it).  So, for a temporary fix, I took the piece that had broken off the crown and drilled it out and then tapped in another threaded stem (and cut off the excess).  I don't have but a couple of old crowns lying around, so I grabbed whatever would fit--as shown.
There are some fascinating features of this movement...click spring, shock jewels...
I wonder if this originally had a two-piece stem.  I need to come up with a solution that compliments the watch.  Maybe go to a one-piece stem, but may have to make it myself.
    • That’s a nice idea, But i’m committed to providing this site as a gift to the watch repair community as my thank you for my incredible life i’ve had in this business. Ive done well and unless my financial circumstances change then i’m more than happy to foot the bill. If circumstances do change then be assured that I will make an appeal. For now, I’m comfortable with the way things are and I am extremely delighted to remove Google Ads from this site and to stop Patreon, it feels like a major step forward 🙂 Sorry, I missed your reply, I got blinded by another poster in this thread. Yes - I can confirm that I have always seen WRT as a not-for-profit website, and therefore - not a business as such. I’m lucky and have done well in my life due to a decision made in my teens to start a watch repairing apprenticeship which has sustained myself and my family for many years now. Consider this my small way of paying it forward. Ive been committed to keeping the site alive on a technical and financial level for over 10 years now and I have zero plans to change that. Thank you for your kind words by the way. And as for your wish - nobody can control what happens in life, if something happens to me I have things in place with my family but I’m just not comfortable talking about my personal business - I wish a certain person would respect that, but i’ve calmed down now - i’m only human 😄
    • Yes, exactly. I've seen a few different versions, but mine has the blue water symbol, not white.    I think it's Acrylic. The case is plastic so I would the is the lens would be too.
    • Hi there Josh, welcome to the forum.
    • From the same listing, the back side: I would guess that the back pops off rather than the front. You can see a little groove there where the caseback sits over the winding stem, rather than a case tube. Look for an indent or notch around the back. It might be possible to pry this off from almost anywhere on the back if it sits right against the rubber strap. The movement looks like it is from the Ronda RL family (015 or 115 or something? I forget which numbers have a calendar and which don't)
    • I'd expect a similar notch somewhere around the rear to pop that off.
