What is the difference between the hand setting "pen"-style tools vs the larger bench-style tools?
GregG
Sometimes when installing hands, I don't feel confident with the loose approach to using the pen-style pressers, since you have to trust that your hand is steady, and slipping could be potentially dangerous to the movement.  I'm looking into the more bench-style tools for stability and its ability to press downwards exactly at 90 degrees, but can't find a resource that describes the difference between the two.
When I was in school last century we pressed hands on with tweezers, preferably nickel or brass. Then towards the end of school a specialist came to teach us chronographs and the first thing we did was make our own nylon pushers from rod- that was a revelation and I've used those or commercial "free hand" plastic tipped pushers since. But I do see the advantage of the devices that keep things nice and vertical and even approaching "codger" status I think I'll buy one just to add to the arsenal. At a hobby level I think you could put your money toward more useful tools though.
  • 1 year later...
Just to add my two cents, I find the vertical tool usually gives a better result especially if the hands are not damaged. In addition to this the tool also forces you to slow down and set up the tool and position of the watch correctly. After a long challenging build and I see the finish line in sight I sometimes rush the final stages and end up taking several steps back (bending a hand, scratching the dial, slipping and dropping the entire movement on the floor)....setting up the hand press tool with the correct nib forces you to take your time. However, if the hands are not perfect sometimes you may need to apply a very small force at something other than perpendicular in order to lift or drop the hand very slightly (fractions of a mm) to avoid it clashing with the hand above or below or the dial chapters etc., and this is best done with the hand pen type tools as you get more of a feel of what is going on. Therefore, I usually force myself to use the desk type tool and then make fine adjustments with the hand tools if required, but as @nickelsilverpoints out you could manage with either tool.
I like to install hands under a microscope. I find that the plastic tipped pens block the view and I can't see anything through the microscope. My spring loaded presser is collecting dust in the drawer.
So, I discovered that there is an Indian made tool from Anchor, that is basically a metal rod with a hole at each end. The watch hand hole is visible through the hole of the presser. But most of the time, I just press it on with a plastic tipped tweezer.
Through trial and error I find that I get the best results by aiming my camera at the dial and viewing on my monitor. One time I was able to see why two hands were hitting one another and it wasn't because the hands were not set properly but because of corrosion on the underside of the minute hand which was scraping along the hour hand.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
