I guess they call them "diver tite" for a reason.
I am trying to install one on a watch.  To the eyeball, the size perfectly matches the crystal that came out.
I am using a BB crystal press and putting the crystal in inverted while pressing in the center and dropping the case on from above.
Of course, there is always the fear of too much pressure.
I have the fitting on the bottom that is concaved so as to cause the crystal to reduce its diameter.  It has a tension ring which must be overcome.
Any advice?
This is not my first crystal to install this way, but I think the thing is so thick...it just takes a lot of pressure.
I see that some people just press them in.  Put the case face up and press the crystal down from the top.  Pretty sure I have done that myself.
Alternatively, I can use THE CLAW!
2 hours ago, JohnR725 said:
I think the link might be what you're looking for. It has the tension ring usually a push on the outer edge. And a lot of people use a plastic bag jbetween the crystal and the crystal press just to keep from damaging it.
https://blog.esslinger.com/how-to-press-a-tension-ring-fit-watch-crystal-into-place-with-a-watch-crystal-press/
Yeah, I have read and watch this before. I may be just 0.1mm too big.  Dunno.
my memory of the last time I did one of those was a heck of a lot of pressure.
how do curiosity did you measure the crystal size? Yes I know it came in a package it was indicated to be a certain size but did you measure the actual size of the crystal? The reason I ask is it was my understanding from the local material house that the crystals can have variations in size.
 With a tension ring don't use the concave pusher from underneath - the crystal is fitted directly into the case/bezel. I have a diagram on my Robur set, will send a picture Saturday if I can't find one online to send.
Ha ha! In my rush to try and answer a question I didn't even notice a solution was given and the problem was already solved!
That is alright...the site you linked is now bookmarked for future reference.  Very nice site.  I have several of those tools.
Yes I did.  Then I compared them when the new one arrived.  Appeared to be the same, but who knows...maybe 0.1mm larger.
48 minutes ago, LittleWatchShop said:
Great to have confirmation that I did it right!!
I learned from my mistakes, thought I could warn you!
    • That’s a nice idea, But i’m committed to providing this site as a gift to the watch repair community as my thank you for my incredible life i’ve had in this business. Ive done well and unless my financial circumstances change then i’m more than happy to foot the bill. If circumstances do change then be assured that I will make an appeal. For now, I’m comfortable with the way things are and I am extremely delighted to remove Google Ads from this site and to stop Patreon, it feels like a major step forward 🙂 Sorry, I missed your reply, I got blinded by another poster in this thread. Yes - I can confirm that I have always seen WRT as a not-for-profit website, and therefore - not a business as such. I’m lucky and have done well in my life due to a decision made in my teens to start a watch repairing apprenticeship which has sustained myself and my family for many years now. Consider this my small way of paying it forward. Ive been committed to keeping the site alive on a technical and financial level for over 10 years now and I have zero plans to change that. Thank you for your kind words by the way. And as for your wish - nobody can control what happens in life, if something happens to me I have things in place with my family but I’m just not comfortable talking about my personal business - I wish a certain person would respect that, but i’ve calmed down now - i’m only human 😄
    • Yes, exactly. I've seen a few different versions, but mine has the blue water symbol, not white.    I think it's Acrylic. The case is plastic so I would the is the lens would be too.
    • Hi there Josh, welcome to the forum.
    • From the same listing, the back side: I would guess that the back pops off rather than the front. You can see a little groove there where the caseback sits over the winding stem, rather than a case tube. Look for an indent or notch around the back. It might be possible to pry this off from almost anywhere on the back if it sits right against the rubber strap. The movement looks like it is from the Ronda RL family (015 or 115 or something? I forget which numbers have a calendar and which don't)
    • I'd expect a similar notch somewhere around the rear to pop that off.
