Hello,
I broke the glass of this Zenith Watch.
Also, there is a plastic washer inside the bezel, internal diameter measured with the washer is 32.06mm, what diameter should I order? Is it enough to add 1/10 mm?
Cousins has 32.0 and 32.5, i'm afraid 32.5 is too big to insert.
Is there any other source recommended?
Thank You for Your help
Edited by Luc
How are you inserting the crystal. I am surprised that the 31.5 does not fit. I presume it is a domed with a flat edge(face) which are only supplied in increments of 0.5. Normal domed come in increments of 0.1.
Hi Clockboy,
I don't know how much the washer can be compressed, 0.5 mm seems a lot to me.
Once the original glass is broken, it is too late to measure it, and I didn't found any reference on Zenith Elite case, only on the movement.
Thanks
Normally called gasket.
Internal diameter measured with the washer is 32.06mm
32mm. If you don't want to take a risk with an expensive crystal that can end being of the wrong size, order first the cheapest flat round one in 2 or 3 increments of 0.10mm.
Yes: Gasket.
Bezel ID is 32.8 mm, so 32.5 mm glass has some room.
Will follow Your advice and order cheap domed mineral or flat saphire to train myself
 Communities specializing in Zenith on other forums know details and often original crystal can be found for sale there. Sterncruetz also makes high quality crystals if want to spend less. There is also the issue of tension ring which pops out when you try inserting the crystal with regular crystal lifts, you need a crystal press.
I am afraid cheap crystals give you a false feel which you need for the task.
This is a quality watch and with a good rebuild serves you another lifetime.
I bought a mineral domed glass 32.5 mm, but couldn't insert it (broke it)
I used a cheap crytal press, this kind: image.png.f33eca248171c077ffb9376008e51998.png
with nylon dyes, put the crystal flat on top of the gasket, but broke it.
Not sure what I should try, another glass and smaller gasket, different press, like this one:image.png.125cd8766cdd55071579afb5b9f2fbb0.png
Any recommendations?
As I had mentioned before, if the opening with gaskets measure 32 or very close to that, you need a 32mm crystal.
Problem is with the crystal die, not the press. You need a die that presses on the rim on the crystal, not on the very top. If it's not in your set you will need to adapt one or get another set.
Did not understood what You meant, just ordered a 32 mm crystal, regarding the dye, it was a 32 mm diameter
20 minutes ago, Luc said:
,regarding the dye, it was a 32 mm diameter
Die diameter is not enough. You must check that it's of the crown type, that is, it presses on diameter of the crystal only, not on the center. For high dome crystals that may mean that it must also have a taper to better fit the crystal shape.
image.thumb.jpeg.250679ffb6a514c28c3022300fe89123.jpegWith a Saphire AR domed 32mm, a new gasket, a beter crystal press, and your suggestions, it looks better now!
Very nice, especially the refined guilloche and drilled lugs. A sapphire domed crystal makes it even more special.
