I have had an obsession for finding a filing rest.  Bid on one recently that went over $350.  Had no clue it would go that high.  I did not get it.
So after looking at what others had done, I decided to try a DIY.  Here is Rev A.  The larger round element is threaded so I can adjust height.
Miles to go before I sleep.
23 minutes ago, LittleWatchShop said:
Yes, I had seen that. His solution is better than mine. If I had the mill he has, I would do something similar.
Before getting a bigger combo machine, I got a TAIG milling column and basic vice from Nick Carter, and used a bit on my Unimat 3 lathe copy. Works OK for light and small size work.
4 hours ago, oldhippy said:
It's a very handy tool to have. Using with an indexing plate shell we say for making a square on an arbor it comes in handy.
Yup...that is why I built this...so that I can make stems.  As is standard for WW lathes, mine has an indexing headstock.
I may need to do a Rev. B of this thing to expand the distance between rollers so that I can get the filing closer to the collet.  I won't know until I do some tests.
  • 5 months later...
Today following a stream of consciousness, I discovered these bearings I had removed from hard drives.  They are perfect for a filing rest.  So, with a little 3D printing...voila!
The bearings from from the read head servo arm.
    • Update!  I've dismantled it, cleaned all the glue off, and rebuilt and lubricated the base movement. I'll leave the chrono part for another day. It's running well - great amplitude and keeping time, but it's got a beat error of 4.8ms.    How important is it to correct this? I'm worried that the potential for making things worse having to take the hairspring off and on repeatedly to adjust this. Would anyone here accept it at that?
    • Since I've been banned from the previous discussion, apparently my language was inappropriate...for small boys. I will start another thread and act in a more decent manner for the girls and ladies of the group.  Please what will happen if the forum can't be managed by the administrator, are there provisions in place to preserve the achived member's questions and answers over the years. Please if I may ask these important questions that are important to the members please.
