I have had an obsession for finding a filing rest.  Bid on one recently that went over $350.  Had no clue it would go that high.  I did not get it.
So after looking at what others had done, I decided to try a DIY.  Here is Rev A.  The larger round element is threaded so I can adjust height.
Miles to go before I sleep.
23 minutes ago, LittleWatchShop said:
Yes, I had seen that. His solution is better than mine. If I had the mill he has, I would do something similar.
Before getting a bigger combo machine, I got a TAIG milling column and basic vice from Nick Carter, and used a bit on my Unimat 3 lathe copy. Works OK for light and small size work.
4 hours ago, oldhippy said:
It's a very handy tool to have. Using with an indexing plate shell we say for making a square on an arbor it comes in handy.
Yup...that is why I built this...so that I can make stems.  As is standard for WW lathes, mine has an indexing headstock.
I may need to do a Rev. B of this thing to expand the distance between rollers so that I can get the filing closer to the collet.  I won't know until I do some tests.
  • 5 months later...
Today following a stream of consciousness, I discovered these bearings I had removed from hard drives.  They are perfect for a filing rest.  So, with a little 3D printing...voila!
The bearings from from the read head servo arm.
