Lantern pinion
Willow
I have just stripped down a tameside time and strike clock which is badly in need of a clean, when i was looking at the fly which has a lantern pinion the pinion is not fixed to the arbour it can turn freely around the arbour, when i put the fly between the plates and turn the lantern with a tooth pick it turns the fly as it should is this right or should the lantern pinion be fixed to the arbour if that is the case how do i secure it, hope you can understand what i am saying i can post a video if you can't instead of a picture.
Take the whole lantern part off. Apply the Locktite red then put the lantern back on making sure it's in the right place and leave it doesn't take long for it to bond. If for some reason you need to move it jut apply a little heat, a hair dryer will do the trick.
Hi i have took the mainsprings out of  the barrels out of the Tameside clock and one of the barrels has a dark substances at the bottom ,which a tried to remove but it wouldn't come off, i just don't know what it is and if i leave it will it have an effect on the spring when i put it back in, any thoughts.
  • Sad 1
Just your thoughts on this tameside clock while it seams quite on the forum,on the front plate where hole for the hammer arbour goes ,they have put a piece of brass with what looks like a oil sink, not that i have done a lot of clocks but i have not seen this before and especically on the other tameside clocks i have done i am just wondering if it was just on this type of movement or have you come across this on other clocks yourself. Thanks
The benefit of that is so the hammer can be taken out without taking the whole movement apart. That hole needs re-bushing and countersinking to form an oil well. No I haven't come across it before. The movement looks as if someone (cowboy) with bad tools has had a right old go, that nut has nasty marks and the screw its head has had a poor fitting screwdriver on it as the head has nasty burrs on it.
HI oldhippy can't see how you can take the hammer apart without the plates taken apart the pinion on the arbour dosen't  protrude beyond the plate the part is on the front side is so thin it looks like a hole has been drilled and then countersunk I was wondering about the screws two of them were hard to get off like they might have to be re-threaded
Are you sure the screws weren't cross threaded. Looks like someone has done a bad repair using solder on the hammer. The hammer is pinned remove the pin and the hammer should just pull off. How do you get on using those movement holders? do you find they help. I never liked using them they were always in my way.
It's still tripping so check the lever and the pin in the wheel and make sure the lever holds the wheel and pin. As it's a count wheel strike are you sure the lever that drops into the count drops right down in the slots and lines up with the wheel with the pin.
4 hours ago, Willow said:
Hi oldhippy tried one video but no joy its saying sorry unknown server problem occurred, not had this problem before
3 hours ago, oldhippy said:
What format is the video in?
Have a read of the thread below:
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
