Lapping machine/disc sander
Hello gurus,
I'm considering getting a disc sander/lapping machine for my workshop. I've been inspired by a couple of videos from vintwatches.de, for instance the one below (https://youtu.be/zYL0kz3Rht0) . Does anyone here have experience with these types of machines and any recommendations/specifics to look for in getting one?
Best regards,
Stian
Edited by Stian
4 minutes ago, Stian said:
Hello gurus,
I'm considering getting a disc sander/lapping machine for my workshop. I've been inspired by a couple of videos from vintwatches.de, for instance the one below. Does anyone here have experience with these types of machines and any recommendations/specifics to look for in getting one?
Best regards,
Stian
It looks like a quick way to ruin a vintage case. Old watches should retain their history.
I have never used one for watch repair or jewelry making but in the right/patient hands they can preform amazingly accurate work or they can be the fastest way to turn something into a bloody piece of scrap.
If your asking for the advice of strangers, the best I can offer you is to be understanding of the danger involved.  Skill and ability will only come to those who pursue them thoughtfully.  If nothing else you may get to keep all the parts you were born with.
Shane
Don't worry Plato, I'm more conservative than most when it comes to polishing watch cases. But there are instances when cases have been misshapen and need restoration, as the video shows very well if you watch it.
Shane
Thanks for the input Shane 😉
I suspect that most of these machines are shop made. If I remember correctly, there was an old post describing one by a Nordic country member. And I think another member showed how to use a lathe chuck to rotate and keep the work in position, and obtain very nice results.
BTW, I'm all in regarding pervasive case restoration, good luck.
  • 3 years later...
I believe @thor447 also has converted a disc sander into a lapping machine, using a voltage regulator to slow its rotation speed. I remember this from a video on Weekend Watch Repair
Edited by mbwatch
On 3/5/2025 at 12:44 AM, ArizonaJones said:
Hello Stian, did you ever figure out the equipment needed to make this lapping machine?
This is a pretty old thread and you are unlikely to get a response here. You might be better off trying to contact Stian via his YouTube channel “vintage watch services”
Tom
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
