This is a little clearer with the directions added. The spring must pull the click back not push. So the opposite way to which the click is being pulled into the teeth. As though its being opened out. Haha you've got it ! I didnt see the picture . Needs to come further around cw. Closer to the long leg. -
Wow , thank you so much for your time ! very kind of you. Here is whaty I end up doing and it seems to work , it needed something to hold on to spring back. out of 10 turns msybe once i have to go back like if i am unwinding 1-2mm but i will make a better one. So now if the hands are works which they should, disassemble and full clean and oiling 🙂
This is how it should be You can always see the direction that the click pulls to by the space provided for it to enter when winding. The spring probably hooks over the rhs of the click. It should have only one turn up for the click the other end will configure inside the milling under the ratchet wheel. -
HAHA omg i think i figured something out, so the left side of the click has to be straight down into the ratchet wheel and other side up. I never thought of letting the left side of the spring once it goes around the click to come straight down to the ratchet teeth... i mean for now its working, the click is not super well bent but will try another one Thank you for your input. 36mm mainplate and dial 35.80 so probabaly 36mm if im not 100 % straight .
