Citizen Eco-Drive Titanium watch bracelet fixed link repair question
I have had this watch since probably 2007-2008. The movement still works great, but the bracelet has some issues. there are probably 3 places where the links have come partially apart. I imagine the only repair is to drill in from the edge of the link and push a new pin through? Then solder and polish the hole? I bought the watch new for $180, a replacement band is $260, so replacement doesn't make much sense. and its titanium, so there aren't a ton of replacement options that I have seen. If I could get a reasonable bracelet that wouldnt look odd with the face, I would be interested.
It is a Citizen H500 S021260
Thanks!
Hi In picture two there are arrows on the bracelet which show the direction in which to remove the pin. First thing to do is to determine whether its the pins that are worn or the links are worn/streched  or the holes are worn. An edge on picture of the bracelet wold be usefull,  It may be a combination of all three things as it looks like the bracelet is coming apart.
Cousins uk,  USA  Jules Borler, Esslingers, Timesavers all material houses who will have stock.
1 hour ago, intoodeep1113 said:
I I imagine the only repair is to drill in from the edge of the link and push a new pin through?
Yes. The problem is with the non removable links that have no arrows. It can't be seen, but there is a cap blended which hides the pin. Once replaced, the hole is normally no big deal to keep, no soldering is necessary. If it just the pin then it's not difficult work but better done by a watchmaker, of course the problem is finding one willing to do it for a reasonable cost.
I don't think you have much chances with a generic bracelet also because it would not match the case profile. Considering that the original bracelet had a relatively short life perhaps your best option is a quality strap that can then be easily replaced.
Yes. I can see "fillings" where the original pin holes were. I'm not afraid to attempt the repair, I imagine I can buy the pins online somewhere and maybe a punch to help the old ones out.
I also saw this, which seems similar to my band and the price is not too bad.
https://www.mastersintime.com/us/en/citizen-promaster-sky-skyhawk-titanium-link-bracelet-59-t00557.htm
These are solid straight steel pins which need to be friction fitted, probably you won't find them ready but can be adapted relatively easy from something else.
  • 3 years later...
Hi, I'm curious how you've resolved this. I also own an Eco-Drive which has been wonderful for over 15 years, but now a pin on the titanium bracelet has broken. Have you found anyone who is willing to repair it? I've only gotten offers to replace the bracelet for huge amounts of money...
    • I recently repaired this movement but the screw for the ratchet wheel was the wrong size and it was bugging me (pic 1). I tried to find a replacement but I couldn't match the head width and tap size, so I decided to make one.  I wasn't sure of the tap size for the screw, but it looked to be either 1.0 or 1.2 so I made a test screw out of a brass bar, with a matching threaded hole on the other end. I didn't photograph this but you can see the bar in picture 4. I settled on a size and proceeded to cut a steel bar down to length. I softened the bar first to make it easier to work with and the cut it to size, using the chart on my tap and die set for reference Once cut I set up the die in its holder and used my tailstock to hold it straight while I created the thread. Once the thread was cut, I tested it using the brass bar Happy with the diameter and thread I cut the screw off the bar and then twisted it into the bras bar to use it as a holder,  for securing it in the lathe to protect the thread I made a face cut to clean the head up Next step was to make the slot. I currently do not have a table saw for the lathe so I was going to have to use a saw. To keep the cut straight and centred, I made a jig out of a piece of brass bar by drilling a hole big enough to slot over the stew, with a slot in it to guide the saw while cutting the slot on the screw head I then cut the slot with a fine saw (I forget what they're called, pin saw?). Once that was done, it was ready for hardening and tempering and then a first polish from 800 grits to 2000 on the lathe. The picture below is just before the first polish. Once I got it to polished with 2000 grit, I removed it from the lathe and then polished it with diamond paste and a Dremel, using the brass bar to hold it. (this turned out to be a really useful tool) Finally, it was ready to go into the movement. I am pleased with the result. I should have made it flatter to match the crown wheel screw better but, overall, it is a vast improvement on the screw that was in there. The main thing I took away from this was how useful the brass bar was, not just for testing the thread but as a holder in the lathe, for cutting the slot and for handling when polishing. No trying to hold it with tweezers or a vice. It was a really simple tool to make and really worth the 10 minuets or so to make it and cut the threads. The slot guide was a huge bonus because it worked much better than expected.
    • I finished a couple of pinions I started yesterday, read up on Breguet hairsprings, made a balance staff, fixed my tool and cutter grinder, and in between checked in here. Having a (2rd) pint with the missus now 😍.
    • I must update myself, I guess nowadays the lubrication procedures and assembly protocols have improved or, at least, changed.  I hope there is still hope for vintage tools in this area.
    • Lol ok, well I'm not about to explain it, I'm a bit fuzzy on it myself, I'll get it all arse about face.....actually that might be part of it, now I come to think about it.
