Name of the parts described?
Similar Content
Thanks Mark I have uBlock Origin Lite add-on for my Windows Chrome browser, so I've never seen a single ad on this site ! It also removes all adds from Youtube - I couldn't bear to watch it without uBlock
Thanks Mark, but can we still discuss the other important matter please and not be distracted from it. Thank you.
