Hi,
I took out the release stem to fix something but when I pushed it back in the watch doesn't work anymore. The release bit doesn't move back and forth like it used to.
I'm a complete newbie to watches so any help would be greatly appreciated.
The watch is a Guess watch,
What you have is a fashion watch, common enough, what has probably happened is the sliding pinion and ita associated parts have become displaced and in doing so has blocked the hacking lever which stops the mechanism when setting the time(for accurate setting)  this has stopped the watch. you will need to reset these components to correct the problem.
The4 movement is an epsonVX3JE  (Hattori)    a dis assembleing document can be forund here https://www.cousinsuk.com/document        If you cant find it just PM me
14 hours ago, LittleWatchShop said:
I found the pdfs here.  Click on "Technical guide"
Thank you both! I really appreciate it!
