After working on a few movements with KIF trior or Novodiac shock springs, I realised that repeated removal and reinstallation of these shock springs tends to deform them slightly, warping them in the direction of the curve of the cap jewel. This means that the shock spring doesn’t press down on to the cap jewel as much, allowing the cap jewel and hole jewel to wobble slightly, and the loose fitting shock spring to rotate itself out of the shock setting.
Does this mean that KIF trior or Novodiac shock springs should ideally be replaced at each servicing? As a short term fix, flipping the shock spring around so that the part bent outwards is facing the cap jewel allows the shock spring to be reinstalled tightly, but I am not sure if this is recommended…
I am using the recommended tools to uninstall and reinstall the shock springs.
Due to the delicate construction of these shock springs I would guess in the professional world they are replaced, but as you have discovered that fitting them in reverse allows for a tight fit. In the amateur world I guess thats acceptable as  the amateur repairer does not have the resources of the professional.  Repeated fitting and removal will eventually destroy the spring.
No, I don't think so. Otherwise that would be mentioned in the service guides, or books.
These may not be the best choice, as metal can be too harsh especially in the hands of beginners. Shaped pegwood may be better, as I'm showing in this video:
Also check related topic:
I find that pegwood isn’t so good for turning the smaller KIF trior shock springs, as it doesn’t have enough grip, or it’s difficult to hollow the inner concave enough to twist the outer tabs on the trior  shock spring into the inner lip of the shock block.
Novodiac shock springs appear to be easier to handle with pegwood, as the incabloc shock block appears to have a taper in the inner lip to allow the tab on the shock spring to engage more easily into the inner lip of the shock block.
This morning I was faced with the KIF Trior issue.  Wondered what tool to use and found this video and then proceeded to put some GOOD pegwood on the lathe and turn it to the right diameter and then hollow the inside.  It worked.  I have done one only and will do the other later today.
After the first, I came here to learn from the experts.  Interesting to see the comments about replacing them with new springs.  A little surprised to see this.
Also wondering what my Dad did.  I do not find a specific tool for KIF and I know they make them.  Guessing he used pegwood too.  Also, I do not see any stock of replacement springs, I suspect he did not do that.
Would you be able to provide a close up picture of the hollowed pegwood? Embarrassingly, I actually managed to break the bottom (dial side) pivot of a balance wheel while installing the KIF trior  shock spring on the balance cock side, which I can only imagine was because the metal KIF tool pressed too hard on the balance cock end jewels.
I am very interested to know how to get the hollowed pegwood to get the tabs of the KIF trior shock spring into the inner lip, since in my experience the outer tabs of the trior tend to bend upwards away from the inner lip of the shock block it is meant to slide into.
I don't think what I made here is all that clever.  It took me several tries on the lathe to get the right diameter.  Once I got the tool to this stage, is was very easy to set the KIF in place.
Just speculating here...but maybe wood is better than metal because you get more friction with wood.  Dunno.
Smaller KIF spring are particularely vulnerable.
There is a tool in set of three sizes for safe removal& repalcement of KIF springs.
Safer approach is; detach the Oscilator and regulator arm, put the bridge on anvil to proceed with removing the shock spring so in case the pegwood or the tool slips, oscilator isn't there and safe.
Just now, Nucejoe said:
Sorry bud, will you just ignore the above post.
I meant to say this local repairshop makes trio KIF tools out of copper on lathe, perhaps you like to consider making one.
Regs
Do you face problems with the wood flaking onto the end jewels? I found that even when the KIF tool worked at securing the trior spring, you could see small gold bits from the metal KIF tool rubbing the gold coloured trior spring.
That sounds like a sensible idea, to make sure the trior shock springs are only installed or removed when the balance wheel is not there. This prevents pivot damage from pressing down on the end jewels when manipulating the trior spring.
However, installing and removing balance wheels from the balance cock also has its risks, although I will probably do that for trior in the future.
Turns out learning watchmaking is from one broken part at a time…
Shock springs are delicate for sure but only if abused do they distort. In theory they should be opened and closed every 5/6 years.
For context, I was taking apart, cleaning, reassembling, oiling the same movement twice a week, among a rotation of other movements. Probably got around 5 cycles out of a 2641 with trior shock springs before one of the trior shock springs broke. The Novodiac shock springs in a 2824-2 are still good though, after 30 cycles of complete disassembly/reassembly of the movement.
The trior shock springs have a harder time engaging into the lip of the shock block, compared to the Novodiac shock springs which easily slip into the inner lip of the block.
Edited by ifibrin
    • I came up with a topic that might be helpful for partners, friends, or family members of watch enthusiasts: gift ideas for people who are passionate about watches. Of course, more watches are always appreciated, but what are some other gift options related to this hobby or collection? What related gifts would you love to receive?
    • Thanks Mark. I think I’ll leave the beat error for now - it’s a fixed stud so I’d have to adjust the collet position.    The watch has bigger problems. On reassembly I’ve found that the hour counter reset hammer is broken - I didn’t do it, the main hammer part was just not there. Can’t easily identify a replacement part. And the subdial hands. The running seconds hand needs an extended pivot tube as the pivot is below dial level. Can’t find one of them either. I’ve found a central seconds hand that might fit it - going to have a go at cutting, filing and polishing it to make it work.
    • Good morning. I have a Caliber 11DO 17 Jewel that I utterly destroyed practicing on. My question is this. Are the 17j and 7j compatible in relation to swapping out parts such as the Wheel Train and Balance? Thank you in advance.
    • Ah ok thanks , i see thing differently now. Won't that catch the wheel rim though ?
    • No Mark it does not offend me. I think I have already started another thread on the matter before you replied. But since you are unwilling to discuss it with us, I will discontinue posting there.  Thank you for considering it though. That's a good policy to have H , you should always safeguard yourself. Knowing who you can trust and who you can't is not a permanent thing. People's values change, people change and adapt to their situations,thats just nature stepping in and running the show. Not everyone is as genuine as you are H. The new no advertising looks much better, it never bothered me much, but it still feels cleaner.  I'm pleased that your thread regarding the missing images was also returned, so thats good news as well. It appears a lot of mine have also been removed ...oh well...🤷‍♂️
