I know Mark has one of these machines, I recently purchased one myself, and its in dire need of restoring.  I have stripped it down, and wish to rewire it and replace the ageing motor speed switch with a modern alternative, so could really do with a wiring diagram if anyone has one?
Hi Micky,
Have you found anywhere that would sell a new rheostat for the elma? Mine has little to no adjustment on the motor speed anymore. I have managed to set it at a manageable speed but it would be nice to ramp it up during the spin-off.
Yes Mark, found a small alternative to the variable motor speed switch...
http://www.ebay.co.uk/itm/New-AC-50-220V-2000W-Motor-Speed-Control-SCR-Controller-Knob-Switch-/251665634527?&_trksid=p2056016.l4276
Also found complete new machines, one without timer, and another twitch timer for £299 and £399 each, but wheres the fun in that?
Prefer to restore my own.
For anyone interested in the new pieces, see below..
http://www.ebay.co.uk/itm/Watch-cleaning-machine-janta-pearl-brand-cleans-rolex-omega-tissot-2045-/111473300849?pt=UK_Jewellery_Watches_WatchAccessories_SpareParts_SM&hash=item19f4539571
With timer..
http://www.ebay.co.uk/itm/Watch-cleaning-machine-janta-pearl-brand-with-timer-cleans-all-watches-2047-/291253631038?pt=UK_Jewellery_Watches_WatchAccessories_SpareParts_SM&hash=item43d011b83e
Janter Branded.
Edited by SSTEEL
I also have one of these elma cleaners, it seems that there is now a buzzing sounds and the switch doesnt really work, after long use there is a slight smell of burning. Im assuming i need to clean up the bearings in the motor and replace the switch.
I could probably figure out the switch,but wouldn't know how to clean up the motor bearings.
Any help would be appreciated.
Thanks
J
I wouldn't be over concerned about the bearings unless they are making a noise. The switch on the other hand will probably be what is making the buzzing sound. If you can't get the switch apart to clean the contacts, I recommend you get a new one sooner than later. In all honesty, you should replace the switch anyway.
Once you have replaced/repaired the switch, run the machine dry and hold the blade of a long screwdriver to the top and then bottom of the motor as close to the bearings as possible, and put your ear against the handle. You will be able to hear how good the bearings are. There should just be a gentle hiss, if they are screaming or rumbling, replace them.
Well my Elma Super Elite is coming together slowly, I have removed all the old paint from the circular base, heater chamber, and motor cover so far with the timer housing and front fascia, and central pole clamp currently soaking in acetone ready for the refinishing.
Base..
15648207765_907ecf80c9.jpgUntitled by Micky.!, on Flickr
Heater chamber, and motor shroud..
15678012071_882950fef3.jpgELMA SUPER ELITE REFURB by Micky.!, on Flickr
I have purchased what I think is the correct hammered blue paint, but I am actually now considering not painting it a colour at all, I might just clear coat it to give it that rustic look, undecided at the moment, so any opinions would be greatly appreciated.
Edited by SSTEEL
That's one hell of a thorough job your doing Micky, I'm looking forward to seeing the end result. Regarding finish, I think I would go with the blue hammered finish, I think it might be more durable and resistant to cleaning fluids.
Thats very useful info - thanks for sharing.
I am sure Graham Baxter uses powder coating when he referbs the L&R machines - is that an option for you?
I have never done powder coating so I don't know what is involved but I understand it is very durable.
Ideally Mark, I would love to have it powder coated, but alas I know of nowhere local that offers this, so what I done is found a very close match blue, with hammered effect, its brush on Hammerite.  I just hope I manage to achieve a nice even coating with it.
Edited by SSTEEL
Hi Micky, for best results don't brush it, dab it on!
That was my original plan, and was going to spray it with clear coat to give it some durability.  I have since etched the surfaces now ready to paint blue, but I do like the idea of a satin finish which I can do with my wire wool.
I placed the jars with new lids into the base just to give you an idea what it would look like if I were to clear coat it, the clear coat is a gloss clear lacquer, which was my preferred option.
15684963742_2c53d6f493.jpgSANY6881 by Micky.!, on Flickr
My L&R refurbished by Graham Baxter was indeed powder coated. It gives the machine a really durable finish which is needed when dealing with chemicals.
Powder coating would be ideal, I agree, but I can't find anywhere local that can do it, but I would be prepared to ship the parts to the UK if needed to be coated. Anyone know if Graham Baxter would be willing to powder coat my parts?
    • These Bulova's will often have a tension ring with a step or cutout where the dial will fit, just in case you are going to try a 3rd party crystal, so be sure and check that. That dial looks somewhat similar to the 1979 Oceanographer '12503', but without the 'Day'. A lot of the '666' Bulova's were Oceanographers or Snorkels. I've been keeping a database of pre-1980's Bulova crystals and it has two 30.2mm armored crystals; 1404AW (Oceanographer 'C' - link has a good photo of the crystal profile) - which I have a note saying that there is a GS crystal PA462-19D, and the 762AW. I think all three of those are currently on ebay, but if the tension ring is stepped it may be an issue. I've had mixed success swapping an existing stepped tension ring into a correct sized crystal that came with a flat tension ring.
    • Thanks for the question. Absolutely nothing has changed in that regard. As you know, I have a points system set-up on the watchfix site and points accrued will never be removed unless used by the user who owns them.
    • Ok, an update. I've attached some pics showing the dimensions of the crystal in question.  As you can see it's quite thick at 4.9mm. I haven't found a decent match yet with GS catalog, I may end up having to grab a few that are close and apply trial/error at this point. Any recommendations from some of you with a heavy vintage Bulova background would be appreciated. p.s. The bezel is in good shape but would not turn at all.  Were these bezels fixed?  It did come off after soaking it a while, along with a rubber gasket inside, which makes me believe it is supposed to turn and is held in place by a thick o-ring (?). Thanks.
    • hello from minnesota, love to tinker with stuff, im 40, getting more stubborn lol, issues arise when i could pay someone to fix something for me,but i just never do it. always learning new skills
