Oh I forgot the base, this was a PITA do clean up, those jar holder tabs cut my fingers up, but the finished product was worth it.  I removed the cork strips that were on there, and have some new cork 5mm sheets to cut some correct sized strips to replace them :)
15665678406_5c81022022.jpgUntitled by Micky.!, on Flickr
Just noticed, that those jar holders can be removed quite easily from the bottom by tapping out the two retaining pegs each spring has.  Wish I found this out BEFORE I shredded my fingers lol
That's a very well made piece of kit when you see the quality of the castings. I'm just about as keen as you to see the end result!
Its getting exciting now Geo, I have finally decided to etch, and coat the casing parts with a few layers of clear lacquer, after all the hard work of removing all the paint, and all the wire wool, and sanding work, it would be a shame to hide it all under a colour paint :)
I have taken photographs of the wiring, so I know how to rewire it, I did initially plan on replacing the large speed controller, but I think I will reuse it as its still working, so too is the motor, and the heater, the latter looks newer than the other components, so I would imagine the heater has been renewed at some point.
Edited by SSTEEL
New wiring purchased, so getting down to the rewiring soon. Waiting for some parts from cousins too, a new heater switch, bulb, and motor base cork ring gasket, the latter is out of stock until the 14th of this month.
Me too, the end is in sight :)
Most of the screws and bolts etc need to be replaced, with the exception of the specialist screws/bolts, hopefully I can find these at my local hardware store. As you can see, many of rusted up, or chewed up.
15722540265_8326cc2345.jpgUntitled by Micky.!, on Flickr
Ssteel
Trust me when you finally get this machine going it will be worth every scratch & bruise. If anything like my L & R the cleaning of a watch just becomes a breeze.
I hear you!  Got quite a few movements already stripped down ready to clean too.  Been cleaning by hand for the last year or so, so this will be lovely to use.
First up in the spray booth is the motor shroud :) This is after one coat, I have since sprayed a second coat, and depending on how it looks, may go for a third coat.
Then the Heater Shroud :)
15794181302_9de3f2a039.jpgUntitled by Micky.!, on Flickr
Edited by SSTEEL
I am so impressed - it's going to be like a new machine.
Now I wonder - would it be beneficial to coat the inside of the drying chamber with that heat resistant car paint, the one you would use on an engine for example. Probably overkill?
Maybe even under the heating element too - to prevent corrosion?
Starting to think maybe I should of started a separate thread for my Elma Super Elite restoration.
Anyway, new varnish in, and final parts now after two coats, a final coat on everything, then will polish the parts to remove any overspray.
15607567849_a9bc0cc8c3.jpgUntitled by Micky.!, on Flickr
15607989078_c8c34f4425.jpgUntitled by Micky.!, on Flickr
15793391765_635f4b2fc8.jpgUntitled by Micky.!, on Flickr
15173955973_a11edd0493.jpgUntitled by Micky.!, on Flickr
15607570279_414f3e1580.jpgUntitled by Micky.!, on Flickr
15173440034_59b106f91c.jpgUntitled by Micky.!, on Flickr
And a few shots now the clear varnish has dried :)
15609339097_738cf6d1bc.jpgUntitled by Micky.!, on Flickr
15770825626_e2e2b0ca0a.jpgUntitled by Micky.!, on Flickr
15609661890_93c07e0047.jpgUntitled by Micky.!, on Flickr
15608676819_7899de3bb1.jpgUntitled by Micky.!, on Flickr
The cast alloy parts, although come out ok, they are not as glossy and smooth as the aluminium case parts, so will need a few more coats tomorrow.
15794505745_67e232b52f.jpgUntitled by Micky.!, on Flickr
15770829526_5d8ee02e71.jpgUntitled by Micky.!, on Flickr
15609098308_d64dfabaef.jpgUntitled by Micky.!, on Flickr
15175067273_d26cf5763d.jpgUntitled by Micky.!, on Flickr
And the base needs one more coat...
15794508715_542d01acde.jpgUntitled by Micky.!, on Flickr
15609347137_884263aecf.jpgUntitled by Micky.!, on Flickr
15794510935_b5178bbf1d.jpgUntitled by Micky.!, on Flickr
Edited by SSTEEL
Lovely gloss finish you have there Micky, when does assembly start?
Thanks, all being well rewiring will start next week, quite busy with work during the week, so only have time at the weekends.
I love how it is coming out! Great job!
Thank you :)
Thanks, the wiring looks like a nightmare, but luckily I was wise enough to take photos of the various wiring, and connections which should help the rewiring :)
Anyhow, some goodies in from Cousinsuk..
Complete basket, this is the alternative to the obsolete Elma item..
15812312405_15a73d4717.jpgUntitled by Micky.!, on Flickr
15627463660_2f33fce27c.jpgUntitled by Micky.!, on Flickr
Gasket for the Motor (Seals baskets in the jars, preventing spash-back.
15626912998_a1dbe93865.jpgUntitled by Micky.!, on Flickr
Heater switch..
15810428181_0655d289c5.jpgUntitled by Micky.!, on Flickr
And new bulb.  I was contemplating fitting a modern motor speed adjuster, and LED light but seeing as the old parts are still working, I serviced them, and they should be fine for some yers to come all being well..
15812315875_0c49552757.jpgUntitled by Micky.!, on Flickr
Wow! Nice and professional! Micky that's one mean machine you are putting together! I bet it will be better than new! Keep it up, great job! If I were a watch I'll be anxious to get a bath in that machine!
@Mark: Hi Mark, nice link, how do they compare in size to the Bergeon ones? I'd like to buy a couple myself!
Edited by bobm12
Sorry Bob, but I never purchased the Bergeon ones so I can't compare.
Nice link Mark wondering if they fit the L&R
Yes - I think they do fit the six compartment tray.
Ah we're back, was having an error page when I tried revising this thread.
Thanks for that link Mark, I have aded that basket to my watch list. :)
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
