Hi I have a Bulova accutron with swiss eta 252.262 movement. The watch is having an issue with the date change function, when I rotate the crown for date change it instead moves the hour hand and not the date wheel. I can continue moving the hour hand twice around and date does changes . The date is changing every 24 hrs .
Any advise how to fix this issue ?
Hi, bit of a vague answer but... I'm not too familiar with this movement but sometimes on a movement (Especially older ones) you have to turn the main hands past the point were the date changes, wind it back to about 9 o'clock then wind it forward again and repeat. until the date is correct (Really annoying when you miss it). You can tell if this is the case because when you wind it back the date will not go back to the previous date. Other watches you actually push the crown in and the date will click round with each push. The final one is that you are missing the first click of the crown. The final click is usually the one that moves the hands. You could try pulling the crown a little softer to see how many clicks there are. If you can adjust the date with the crown please make sure the time is before 9 O'clock as the mechanism which adjust the date normally (by the time just moving forward), will have already engaged and it may damage it.
Hope this helps
Hope this helps
Forgot to add that if you do find it is the first of the two clicks to alter the date (Quick set function) on some watches it will only work in one direction of turning to advance only.
Failing all this it may have an actual mechanical issue (Doh!!) 🙂
@Deomandinka thanks for responding. It is actually the first click. The click is pretty absolute. I tried moving the main hands back and forth at date change point didnt help. Here is a link to a quick video I made to show what's happening if I am trying to change the date
LOL, there is no quick set on these watches. It is changed with the "Time Zone" i.e the hour changer.
Here is the manual for you
https://content.abt.com/documents/36109/Swiss_Army_Chrono_Instructions.pdf
Enjoy 🙂
That's how it's supposed to work. My Tag changes date in exactly the same way. The hour hand is moving separately from the rest of the movement which allows it to keep time whilst changing the hour or date.
Ha ha! No worries, when I first bought the watch (some 25 years ago) I thought it was dodgy, there's a fair bit of resistance when you turn the hour over - it didn't feel right at first.
    • I came up with a topic that might be helpful for partners, friends, or family members of watch enthusiasts: gift ideas for people who are passionate about watches. Of course, more watches are always appreciated, but what are some other gift options related to this hobby or collection? What related gifts would you love to receive?
    • Thanks to everyone for the welcome.  Can I ask for some advice?  I have a French Drum clock which I am hoping to dismantle, clean and mend a bit for a friend (it is a long time since I did this, but I would like to restart). I used to go to M & P for supplies but it seems they are out of action at the moment.  Is Cousins a good place for supplies?  I think I will need: 1. Some small watchmaker type screwdrivers 2. Cleaning fluid to put in a bath and agitate the parts in (I don't have an ultrasonic bath and was not proposing to get one) 3. Clock oil 4. Some thin nosed pliers for removing pins 5. A basic magnifying eyeglass 6. A pivot locating tool 7. An assembly support for the movement 8. Some assorted pins .. but probably nothing more than that for the moment.  I don't think I will need to rebush any holes although I do have the tools for this.  The hour wheel is broken but I hope I have sourced a replacement. Final queries:  a. the wooden case has split a bit.  To glue it together, would standard strong PVA glue e.g. Evostik interior wood glue be OK?  b. to polish the exterior brasswork of the face and rear, is Duraglit OK, and should they be lacquered after polishing?  I am not proposing to polish and lacquer the movement itself, unless that is vital, but only to clean it in the cleaning fluid. Thanks in advance and I hope this is clear.
    • Thanks Mark. I think I’ll leave the beat error for now - it’s a fixed stud so I’d have to adjust the collet position.    The watch has bigger problems. On reassembly I’ve found that the hour counter reset hammer is broken - I didn’t do it, the main hammer part was just not there. Can’t easily identify a replacement part. And the subdial hands. The running seconds hand needs an extended pivot tube as the pivot is below dial level. Can’t find one of them either. I’ve found a central seconds hand that might fit it - going to have a go at cutting, filing and polishing it to make it work.
    • Good morning. I have a Caliber 11DO 17 Jewel that I utterly destroyed practicing on. My question is this. Are the 17j and 7j compatible in relation to swapping out parts such as the Wheel Train and Balance? Thank you in advance.
    • Ah ok thanks , i see thing differently now. Won't that catch the wheel rim though ?
