Lorus Analogue/Digital copper tail
By CARBONLACE · Posted
Good morning. I have a Caliber 11DO 17 Jewel that I utterly destroyed practicing on. My question is this. Are the 17j and 7j compatible in relation to swapping out parts such as the Wheel Train and Balance? Thank you in advance. -
Ah ok thanks , i see thing differently now. Won't that catch the wheel rim though ?
