Hello,
I have a question regarding the hair spring.  I have a vintage Durowe movement I am getting running again.  The only thing it needed replacing was a hairspring.  I found a NOS hairspring and balance wheel in France thru Ebay and ordered the part.  When the part arrived I laid it across the balance cock I noticed that the bend in the outer coil was at the stud and with the spring over the regulator pin the outer coil is still concentric.
Now I know that the outer coil leading to the stud needs to be concentric with the rest of the coils but all the movements I've worked on, which isn't many, all had the bend and stud carrier on either side of the regulator pin.  The way this spring is set up, the stud carrier and regulator are on either side of the bend and Im wondering if this is acceptable practice?
Thanks,
George
I am not sure but I think I understand what you are describing.
The bend can be either at beginging or the end of terminal curve or two bends one at the begining the other at the end of terminal curve.
         What matters is the coil is to breath evenly.
Hope I guessed right and this helps.
Older movements offen had the terminal curve almost imperceptibly developed from the outermost coil, with a pronounced kink just before the stud. What you are describing sounds OK, but as others have pointed out, a picture would be very useful.
    • Books, or some sort of voucher to a material house if they do them. You can never read and learn enough and if you find a material house that could do a gift card then the person could pick things they really need.   Tom
    • I don’t know what a pivot locating tool is? I am not a clock guy though but everything else you mentioned cousinsuk should be able to supply without issue. you might get more results if posting in the clock section of the forum.   Tom
    • I came up with a topic that might be helpful for partners, friends, or family members of watch enthusiasts: gift ideas for people who are passionate about watches. Of course, more watches are always appreciated, but what are some other gift options related to this hobby or collection? What related gifts would you love to receive?
    • Thanks to everyone for the welcome.  Can I ask for some advice?  I have a French Drum clock which I am hoping to dismantle, clean and mend a bit for a friend (it is a long time since I did this, but I would like to restart). I used to go to M & P for supplies but it seems they are out of action at the moment.  Is Cousins a good place for supplies?  I think I will need: 1. Some small watchmaker type screwdrivers 2. Cleaning fluid to put in a bath and agitate the parts in (I don't have an ultrasonic bath and was not proposing to get one) 3. Clock oil 4. Some thin nosed pliers for removing pins 5. A basic magnifying eyeglass 6. A pivot locating tool 7. An assembly support for the movement 8. Some assorted pins .. but probably nothing more than that for the moment.  I don't think I will need to rebush any holes although I do have the tools for this.  The hour wheel is broken but I hope I have sourced a replacement. Final queries:  a. the wooden case has split a bit.  To glue it together, would standard strong PVA glue e.g. Evostik interior wood glue be OK?  b. to polish the exterior brasswork of the face and rear, is Duraglit OK, and should they be lacquered after polishing?  I am not proposing to polish and lacquer the movement itself, unless that is vital, but only to clean it in the cleaning fluid. Thanks in advance and I hope this is clear.
    • Thanks Mark. I think I’ll leave the beat error for now - it’s a fixed stud so I’d have to adjust the collet position.    The watch has bigger problems. On reassembly I’ve found that the hour counter reset hammer is broken - I didn’t do it, the main hammer part was just not there. Can’t easily identify a replacement part. And the subdial hands. The running seconds hand needs an extended pivot tube as the pivot is below dial level. Can’t find one of them either. I’ve found a central seconds hand that might fit it - going to have a go at cutting, filing and polishing it to make it work.
