Prototypes
1 hour ago, watchweasol said:
Your work does you credit.  I like the blue one, it has that timeless appeal and I think will always be in fashion like the black. Keep up the great work.
Thank you. That’s all the encouragement I needed. I’ll nickname it the Weasol.
The OROLUX Weasol is done!
Ha  Ha   I like that,  how about "The Weasol Watch Co"   No thats going a bit too far.   But I like the simplicity and un fussy style it is to me classic.  When you look at it it tells you the time, its prime function without complication.      like I said  Clsaaic.             cheers
Had a bit of a play this afternoon with trying to achieve a spun dial finish (rather dangerously I fear). It inspired me to adapt an old design, and try something new. Comments and criticism are gratefully accepted as usual.
Once again these are ‘fast and dirty’ proof of concept creations.
Hi  They may be down and dirty proofs but they are still quality, I have seen watches sold with worse finishes than those for sure. I would like to see your finished article if those are proofs.  Classic, clean and simple.
Thank you once again for the kind words watchweasol. I’m currently collecting supplies to start a finished watch. May need to spend some time improving my enamelling technique first tho!
As soon as I finish something, you guys will be the first to know.
The Orolux ‘Mil-spec’ (working title, lol) has arrived! I can’t believe how excited I am! I know it’s very similar to every other military inspired watch out there, but this one is mine (guess the military film reference). And I’m pretty sure most modern mass produced military watches don’t have an enamel dial.
Hi   they are looking good  The hands  would suit either  lume or not My preference  no lume,  I think the case suits the style and a flat crystal to keep it slim.  The only issue I would have is with the second hand whilst very cleverly done I think a plain one would be better as the current one takes the eye away from the actual watch. Again my preference alone, others will have a different opinion I am sure.  Bur a cracking job well done.
I very much appreciate your opinion watchweasol, and believe I completely agree with you. With a clear head brought about by a new day it’s easier to be objective. I’ve already ordered a flat crystal as well as one with a slight dome to try out. I think this will make the watch much more wearable. After measuring the height of the hand stack I reckon I could fit a flat crystal as well as removing 1.5mm from the bezel height. I think this will transform the watch. As much as it pains me to say it I agree with you regarding the seconds hand too. It just doesn’t suit the watch.
I’ve actually found a case for sale in Japan that fits a 6498 and is only 40mm in diameter and 11mm thick. It’s expensive but looks top quality. I’m very tempted to give it a try. As I get older 44mm feels just too large!
Just so watchweasol doesn’t think I’ve forgotten about him, here are some progress photos. Bezel has been slightly reshaped, the case has been refinished, the seconds hand has been changed, and it has a new flat glass. Total watch thickness now down to 11.5mm. Much better.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
