My wifes Lorus watch has a failed movement, That's easy to remove and replace bur the rear of the case wraps under and I can't see how to get at the front of the face to replace the hands.
Anybody dealt with one of these before please?
Thanks
Roy
That construction is called "front loader" and is very frequently asked by beginners. Enter the search including double quotes in the box top right to obtain the relevant answers.
Since no pictures have been posted since no picture have been posted, please keep in mind that is required for pretty much any question.
Here's a couple of pics.
I'll run the search this evening.
Initial thought is that there doesn't appear to be a break at the front to create a bezel
Hi  from the pictures it is not easy to discern whether the bezel is removable or not apicture or two of a side on view from both sides would help.  If the crystal is acrylic it may be lifted out, but to do that you need a tool. If its glass the case will need to be split. I notice there is only one dial foot left is the other stuck in the front plate?.
Likely there is, but we can't tell because no side picture has been posted.
If there is not, check below video by our host Mark Lovick. Note that a pump tool is also available, which works much better than a syringe.
Replace the caseback and apply low pressure compressed air through winder. Glass will pop out.
An 8bar+ air source is way, way too much!! (Don't ask😳)
Thank you all for the fast and helpful replies.
philipk5 - that sounds like a good ide.
I have 3 options
Car tyre 12 volt compressor ( too high?)
Bicycle tyre pump
Air duster compressed air can.
Number 3 is my best guess?
what do you think?
BTW...
watchweasol -
By dial foot do you mean the hands?
They are all there under the crystal as the popped off when I removed the movement.
Bicycle tyre pump of your three options should do it.
Or follow Marks method with a syringe (He seems to know what he's doing! 👍)
Dial feet are the small studs that locate the movement to the back of the dial.
The problem with using a syringe, or other improvised air source, is that getting a good seal to the pendant tube is hit and miss.
The dedicated tool below comes with enough nylon tips, is not expensive, and unlike the syringe, has not failed me so far.
https://aliexpress.com/item/4000233469611.html
You've got away with not breaking them because this being a basic watch has them just fitted in holes on the module or plastic ring. Other types use screws for a positive lock. It's never a good idea to go by force on watches. One need to know first what is what and why, and get the proper tools to proceed.
Thank you everyone for your assistance.
Thankfully both dial feet are still intact, the image doesn't really show that.
It's opened my eyes to an interesting pastime and I look forward to digging out all those old, non functioning watches and clocks in the cupboard!
