For a good pre-clean, brush the parts ( while still wet) using a bit of powdered detergent.
In case part have dried now, resoak in CocaCola before brushing.
I give the parts couple of cleans in unltrasonic after the pre clean.
I think anything with phosphoric acid would work. I used to have a lime scale remover product from Germany. I think it was called Sillit or something like that. Best stuff for removing rust and tarnish.
But remember to wear gloves. Good ones even. Because latex surgical glove would disintegrate. 🤪
Hi Dr.    Questions
Phospheric acid here come in two litter bottles( the smallest ) , its by merc and high concentration.
How do I delete this acid?  would distilled water work?  What ratio of acid water solution and gloves.
I am expecting better results out of higher acid concentration.
TIA
8 hours ago, watchweasol said:
Brilliant  the moral of the story is drink coke a cola    probably cleans the intestinal tract?   Joe does coke zero work as well.
Ya, pringles new fangle potato chips and coke for a nice snak.
@JS335   I forgot to mention the type of brush, one with strong bristles, used tooth brush will do,  you are scrubbing as you are  brushing, little water on the powdered detergent sort of cleansing with powdered detergent.
Rinse under tap water and keep brushing as you rinse.
1 hour ago, Nucejoe said:
Hi Dr.    Questions
TIA
I have no idea. Concentrated phosphoric acid is about 85%. Coke claims there is only 50-70 mg/100ml of phosphoric acid in their drink. So I guess it wouldn't be more than a teaspoon per litre. You'll have to test it by trial and error.
But I'm shocked that you can buy concentrated phosphoric acid without a license. 😱
This young lady chemist friend of mine works at labratory in oil refinery, she gave me the list and can get me some from merc . She has no idea either as to  what concentration works for watch cleaning. I don't want get burns or explode.
It also works well for preclean.
Thanks for your reply Doc.
    • Books, or some sort of voucher to a material house if they do them. You can never read and learn enough and if you find a material house that could do a gift card then the person could pick things they really need.   Tom
    • I don’t know what a pivot locating tool is? I am not a clock guy though but everything else you mentioned cousinsuk should be able to supply without issue. you might get more results if posting in the clock section of the forum.   Tom
    • I came up with a topic that might be helpful for partners, friends, or family members of watch enthusiasts: gift ideas for people who are passionate about watches. Of course, more watches are always appreciated, but what are some other gift options related to this hobby or collection? What related gifts would you love to receive?
    • Thanks to everyone for the welcome.  Can I ask for some advice?  I have a French Drum clock which I am hoping to dismantle, clean and mend a bit for a friend (it is a long time since I did this, but I would like to restart). I used to go to M & P for supplies but it seems they are out of action at the moment.  Is Cousins a good place for supplies?  I think I will need: 1. Some small watchmaker type screwdrivers 2. Cleaning fluid to put in a bath and agitate the parts in (I don't have an ultrasonic bath and was not proposing to get one) 3. Clock oil 4. Some thin nosed pliers for removing pins 5. A basic magnifying eyeglass 6. A pivot locating tool 7. An assembly support for the movement 8. Some assorted pins .. but probably nothing more than that for the moment.  I don't think I will need to rebush any holes although I do have the tools for this.  The hour wheel is broken but I hope I have sourced a replacement. Final queries:  a. the wooden case has split a bit.  To glue it together, would standard strong PVA glue e.g. Evostik interior wood glue be OK?  b. to polish the exterior brasswork of the face and rear, is Duraglit OK, and should they be lacquered after polishing?  I am not proposing to polish and lacquer the movement itself, unless that is vital, but only to clean it in the cleaning fluid. Thanks in advance and I hope this is clear.
    • Thanks Mark. I think I’ll leave the beat error for now - it’s a fixed stud so I’d have to adjust the collet position.    The watch has bigger problems. On reassembly I’ve found that the hour counter reset hammer is broken - I didn’t do it, the main hammer part was just not there. Can’t easily identify a replacement part. And the subdial hands. The running seconds hand needs an extended pivot tube as the pivot is below dial level. Can’t find one of them either. I’ve found a central seconds hand that might fit it - going to have a go at cutting, filing and polishing it to make it work.
