I ordered a 30mm diameter glass, it measured 29.88 and was (obviously) too loose. Should glass measure exactly as stated or is the measurement always smaller (like wood)
Thanks
Jim
Welcome Jim - enjoy the forum.
Whenever I've replaced watch crystals, I've gone to a repairer friend of mine who has a massive stock. We get the so-called correct size out of the packet only to discover, sometimes, that the bezel actually needs either a size smaller or larger - in spite of the packet labelling! It can certainly be a problem.
Jim, welcome to the forum.
This is reasonably common with replacement glasses. When I order I will usually obtain the one above and the one below and whatever I don't use goes into my parts collection.
Welcome to the forum Jim. You should get answers to most of your horological questions here.
Welcome Jim,
It happens sometimes and it is more like a guesstimate considering you don't really know how the new crystal is going to fit since tolerances are + or -. All that said, one size up and one size down as Mark said is the way to go!
Hope this helps,
Cheers,
Bob
    • From what I see, the crystal is made of mineral glass and is secured to the bezel with a sealing ring. If you might want to replace the crystal without removing the bezel or the movement, I think it's possible, but risky. You have to suck out the old crystal without breaking it into tiny particles. I would not do that. If you remove the movement first you can press the crystal out and press a new one in without removing the bezel.
    • Hello Everyone, A short message to introduce myself. I'm Sebastiaan (50) from the Netherlands and have always been interested in watches. My two kids are at the end of their teens years and so I have more time to start a hobby.  Working on watches was something I always wanted to learn. So I recently started the watchfix repair course. Currently watching level 3. My short term goal is to be able to service the watches we (Myself, my wife and kids) own. I own a manual Omega Geneve from 1974, a small microbrand watch with a NH35 and a wittnauer bumper from 1940's. My wife owns an Oris, Seiko 5 with 7s26c and my son a seiko alpinist sarb017 and sports 5 with 4R36. So enough to learn on the short term..  Looking forward to talking to all of you and enjoying the watch hobby together. Greetings Sebastiaan
    • It works quite well. The only strange thing is that it loses 2/3 mn per day whereas the measurements indicate that it is fast by 1/2 mn. Maybe something wrong with the gear mechanism ...
    • Unfortunate…but you clearly have a Longines branded movement with a year 1936 serial consistent with the caliber. I checked the case maker of the last few Longines I worked on… …same as your watch, so certainly you have grounds to honestly describe your watch as a Longines cal 25.17 tank with unbranded dial…and given the modesty of the watch IMO the Longines authentication wouldn’t dramatically alter the value, if that’s what you are hoping…as nucejoe suggests the value will mostly be determined by how well it runs…
    • It's difficult to tell, but my guess is it just looks like it has a bezel. Once you have removed the movement, you should be able to tell. Either way, I think you should be able to press out the old crystal from the inside as long as you have a die that properly supports the area around the crystal. So, take it a part first and then assess if any additional tools or actions are needed. Let us know how you do!
