Anyone doing pivot work?
rustycolt
In a terribly annoying case of 'I should have stopped and gone to bed a half hour ago' I find myself with a broken pallet pivot. As a hobbyist, I haven't got the tooling to repair it myself. Any fin upstanding WRT members with the ability to fix this willing to help a guy out? Happy to pay for the time of course 🙂
@JohnR725 - have you read this post yet?  I know you've spoken of pivots also, but this is a clock rather than a watch.  I'm guessing the principles are the same but the tools are bound to be a tad larger.  I cannot advise here, out of my depth to be honest.  Would you know what we could tell Rustycolt?  Any trusted people in the industry he could take this to?  Or can you do clock pivots as well?
So far no luck. Nobody local performing this type of service, and by local I mean within 500km (or even in Canada for that matter). I've sent out some service requests to various establishments in the US, but oddly, I'm more comfortable with the members here in terms of having the work performed with care and consideration, regardless of their location!
I'd love to tool up and advance my skills, and I feel like I constantly am doing just that. Most of my projects are watches, and there is a pretty long list of tools to add there as I progress into more complex jobs. I work on one, maybe two clocks a year just as a curiosity. If I see something mechanical in the classifieds that isn't expensive, it ends up in pieces on my bench basically 🙂 Perhaps I'll dive a bit deeper with them in the future, but there are a number of very basic tools that would be required before I was ready to shop for a lathe. For now I am at the mercy of the good people here for guidance. My fingers remain crossed, and my gratitude to those participating remains extended!
6 hours ago, HectorLooi said:
What about using a quick pivot?
I know that OH will be tearing his hair out at the mention of quick pivots, but consider the possibility. 🤪
🤣 I must say that is the easy option when you have no other way. I don't recommend using a nail. The broken pivot is on the pallets and they have to be a certain depth to the escape wheel teeth. Drilling a hole has to be right center in order for the escapement to work, you will never get the pivot to be the excite diameter by using sandpaper.
HectorLooi I don't have much hair to pull out these days. 🤣
It might be a bit of good fun to try to 'turn' my own pivot by strapping a drill to the bench and using what I have lying around, but I'm going to steer clear of work that has the potential to make a proper repair to the part impossible. ...ask me how I learned THAT lesson. I actually have a paper clip that is exactly the correct diameter if I wanted to attempt that type of bodge, but drilling the pinion to accept it is where disaster surely lurks.
This is the nicest clock I've personally owned, and my first longcase. It took me years to find the right one, so the last thing I want to do is turn a curable fault into an incurable one by being 'resourceful'
Quick pivots are an option, but I think a last option. Surely I'll be able to locate a reputable and qualified repairer, and though it isn't perfect, the modern mail system stands a pretty fair chance of delivering and returning a package. It really does, right? 🤨
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
