Is the hairspring correct for this pocket watch?
By CARBONLACE · Posted
Good morning. I have a Caliber 11DO 17 Jewel that I utterly destroyed practicing on. My question is this. Are the 17j and 7j compatible in relation to swapping out parts such as the Wheel Train and Balance? Thank you in advance.
