Hope someone can advise me please. I have recently acquired a watch with a compressor back. The back turns quite easily with a ball but I can’t remove it. I have tried numerous different ways of easing it off but no joy. Has anyone had any experience of removing please. There must be a technique that I’m not aware off. Any help greatly appreciated.987AE875-BDE0-4577-9291-8C2EEE8ACC7F.jpeg.df4d996a7d4867abd8d2fafa549ed193.jpeg
Have you tried a case knife. Have a careful look around the edge of the back and you should see where blade will fit in then pry it off.
A ball is used to unscrew a back. Your watch is not a screw on back.
I think Brevet is then French word for patient. Is there a makers name on the dial side. I agree with OH it very much looks like a friction fitted case back.
The Compressor and Super Compressor cases were made by EPSA. Super Compressors use either a screw on case back or a bayonet (I think for Enicar), but Compressors are a snap back. That being said they can be fiendishly tight and quite challenging for a standard case knife but it can be done. They should have 2 O ring seals as far as I can remember, if your case back turns quite easily then that would suggest that they may be missing.
Thank you all for the responses. It turns freely with a ball and there is plenty of room to get a knife in but it will not budge. I thought it may be a bayonet as well and have tried it at every position with a suction tool but again no joy. It’s very loose but just will not part. I’m stumped.
  • 1 year later...
Hi,
Recently I got a compressor case where I experience the same issue. The case back rotates but I cannot take it out. The caseback is loose but something is securing it.
4 hours ago, Henrique said:
Hi,
Pictures?
Not at home...I will get back in 2 months :(.  I just posting the pictures from ebay. The caseback is of screwback and rotates, but cannot remove it yet
You might want to have a look at this article to make sure that you correctly identify what you have got.
The original EPSA Compressor and Compressor II cases were snap on backs, while the Super Compressor was mostly screw on, with a few bayonet fit backs.
The lack of any notches in the back strongly suggests that you have a Compressor or Compressor II which is a snap back. The fact that it rotates suggests that the rubber gaskets are actually missing or have been replaced with gaskets that are too small.
    • Update!  I've dismantled it, cleaned all the glue off, and rebuilt and lubricated the base movement. I'll leave the chrono part for another day. It's running well - great amplitude and keeping time, but it's got a beat error of 4.8ms.    How important is it to correct this? I'm worried that the potential for making things worse having to take the hairspring off and on repeatedly to adjust this. Would anyone here accept it at that?
    • Since I've been banned from the previous discussion, apparently my language was inappropriate...for small boys. I will start another thread and act in a more decent manner for the girls and ladies of the group.  Please what will happen if the forum can't be managed by the administrator, are there provisions in place to preserve the achived member's questions and answers over the years. Please if I may ask these important questions that are important to the members please.
