Hello I am new to this forum.  My interest is Carriage clocks. I am looking for an original rear door to fit to one of my gorge cases. The measurements of the door needed are 91 x 70 mm. that is 91 high and 70 wide. I would hope to have the frame and the bevelled glass but if you have the brass frame only then I will be interested in purchasing. If your frame is larger and I can cut it down to my sizes then lets try that.  if the frame you have is even a mm over my sizes then I will reduce it. Again let,s see what materialises. thanks  in anticipation.  Kevin.
Hi Kevin, enjoy the forum. Finding an exact door or a door will be difficult. It will be either ebay or if you have the original door then repair it.
Thanks Clockboy for your quick reply. I have no longer got the door . It was ditched before I had the clock. Therefore a repair that I would have attempted is out of the question but there may be someone out there who has one to repair or even have a good one that is almost a fit. Alternatively someone could have an oversize one that I can alter. Failing that if anyone has the rails that make up a door frame then that's another possibility.  Is there anyone in the forum who either cuts and bevels  glass of that size?    Thanks again Kevin.
    • I came up with a topic that might be helpful for partners, friends, or family members of watch enthusiasts: gift ideas for people who are passionate about watches. Of course, more watches are always appreciated, but what are some other gift options related to this hobby or collection? What related gifts would you love to receive?
    • Thanks to everyone for the welcome.  Can I ask for some advice?  I have a French Drum clock which I am hoping to dismantle, clean and mend a bit for a friend (it is a long time since I did this, but I would like to restart). I used to go to M & P for supplies but it seems they are out of action at the moment.  Is Cousins a good place for supplies?  I think I will need: 1. Some small watchmaker type screwdrivers 2. Cleaning fluid to put in a bath and agitate the parts in (I don't have an ultrasonic bath and was not proposing to get one) 3. Clock oil 4. Some thin nosed pliers for removing pins 5. A basic magnifying eyeglass 6. A pivot locating tool 7. An assembly support for the movement 8. Some assorted pins .. but probably nothing more than that for the moment.  I don't think I will need to rebush any holes although I do have the tools for this.  The hour wheel is broken but I hope I have sourced a replacement. Final queries:  a. the wooden case has split a bit.  To glue it together, would standard strong PVA glue e.g. Evostik interior wood glue be OK?  b. to polish the exterior brasswork of the face and rear, is Duraglit OK, and should they be lacquered after polishing?  I am not proposing to polish and lacquer the movement itself, unless that is vital, but only to clean it in the cleaning fluid. Thanks in advance and I hope this is clear.
    • Thanks Mark. I think I’ll leave the beat error for now - it’s a fixed stud so I’d have to adjust the collet position.    The watch has bigger problems. On reassembly I’ve found that the hour counter reset hammer is broken - I didn’t do it, the main hammer part was just not there. Can’t easily identify a replacement part. And the subdial hands. The running seconds hand needs an extended pivot tube as the pivot is below dial level. Can’t find one of them either. I’ve found a central seconds hand that might fit it - going to have a go at cutting, filing and polishing it to make it work.
    • Good morning. I have a Caliber 11DO 17 Jewel that I utterly destroyed practicing on. My question is this. Are the 17j and 7j compatible in relation to swapping out parts such as the Wheel Train and Balance? Thank you in advance.
    • Ah ok thanks , i see thing differently now. Won't that catch the wheel rim though ?
