Hi Blacksmiths Locksmiths Clock and Watchmakers,
could you please give me an advice as what UV light to buy to cure my Sternkreutz UV glue? Tried to google it, but cant say that i got a clear picture. I have a UV light I used to use for making electronic circuits in the past - to cure the stuff I sprayed on the board, it was called positive 20 as far as I remember - but it does not seem to do the job.
Best regards,
Lui
Edited by luiazazrambo
I remember Positiv 20. Real stinky stuff. I used to use backlight UV tubes for that and it takes forever to get a good exposure.
Then I discovered 500W floodlamps. Those were awesome. I could get a good exposure in a couple of minutes.
I too have Sternkreuz UV glue and bought 3 different LED UV lights for curing it. 2 of them don't work at all. The 3rd one is a 405nm LED light. But even that seems to give a rather weak cure. The glue doesn't seem to set very well. The best way I found was to leave it in the sun for 30 minutes.
I hope other members can give you better advice.
UV lamps lose intensity with use, I'm sure the one you had for photoresist would be fine but is maybe too old.
We use a lamp for curing UV nail polish. Looks like the toaster oven my grandad had. Works great. If you search for lamps for nails I'm sure you'll find one.
UV nail polish lamp the only thing i thought that could work I just could not go for it. 😄
Strenkreutz recommends Osram Ultra Vitalux, rtfm. 🙂 I could not figure out what frequency range it does.
https://www.osram.com/ecat/ULTRA-VITALUX UV-A-UV-A-Ultraviolet lamps-Industry-Specialty Lighting/com/en/GPS01_1028569/ZMP_60829/
Positive 20 wants light between 340 and 420 nm.
Best regards,
Lui
I have used this little torch for 'Bondic' curing adhesive but it takes a while to cure.
7 hours ago, luiazazrambo said:
The osram ultra vitalux emits the UV light on the 365nm and 400nm the best. The tubes what are for sale as replacement tubes for nail curing lamps seem to operate with 365nm waves. We also can buy power UV LEDs for the whole UV range.
This is a good text to read:
https://www.permabond.com/resource-center/factors-affecting-uvcure/
Yeah there are better UV-A LEDs out there, but at what cost?
I a while back i bought a crazy bright UV-A source to rebuild my 1st gen anycubic photon with. Allegedly allows layer curing in under 2 seconds. But it was something like $70.
I use a Ultraviolet Counterfeit Money Detector - Amazon sell them. They have the correct UV frequency for the Sternkreutz UV cement. Takes about 5 minutes with the watch crystal on a foam pad under the UV tube.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
