Bulova microscope...useful as a general-purpose bench tool?
LittleWatchShop
The idea hit me...the microscope is stored in the closet in its pretty little wooden box--I do not work on Accutrons.  My Dad bought it.  I remember him asking my opinion--I was graduating engineering school.  It is pristine.
I have a stereo microscope with a very nice and huge boom stand...too big for the bench.  I use it for inspection often.
So...why not use this cute little thing on the bench.  It has limitations of course.
I am going to give it a try and see just how useful it can be.  I am sure @JohnR725has an opinion.  I am sure he has one.
Just now, HectorLooi said:
Why not?
Because I have not mastered the other stuff!!  I have a friend who asked me to fix his.  I want to (he is a friend), but I feel it may be a steep learning curve.  Also I have about six clocks in the queue, another Vulcain Cricket, and a drawer full of miscellaneous mechanicals.  I will never get bored.
Looks like you've got your hands full.
But Accutrons are really interesting. They are the only watches with true burnt coils, unlike quartz watches. Quartz coils normally break when someone slips with a screwdriver and scratch the surface. Accutrons have open coils with absolutely no visible physical damage.
If one can repair the burnt coils, Accutron owners will beat a path to his front door.
Fuzzy memories they can't white focus on? Some worry saw the suggestion that the wire breaks at the solder connection. With the suggestion that may be the protective coating holding the wire is maybe? Don't love was thermal expansion and differences of something but basically the wire would break right at the joint. With the suggestion that you could just apply a little solder and fix the wire again. Zero idea how that plays out in real life.
Typically as far as physical destruction it was only the 218 cell coils that got destroyed from bad battery changing. This is why supposedly in the US we ran out a cell coils before everywhere else in the world because all sorts of interesting people change batteries with zero experience. Basically all the places where you get a battery change the watch that they barely grasp what a watches. My favorite used to be what I'd go to whether drugstores in the old days we get a film processed and did look on the floor you'd see spring bars because in addition to taking your film and getting a process to change the battery in your watch how much skill could be required to do that obviously none.
Then I believe there's somebody out there that rewinds the coil's.
You suspected correctly that I have one it's sitting in the other room now with its protective cover on. Yes it should be in the box but not quite sure where the boxes right now. Considering the price it really isn't a bad microscope and it does exactly what it's supposed to do. I find typically I have a hard time using stereo microscopes as my left thigh is so much stronger than my right I just have a hard time. So it works out fine only have a one lens.
But I have seen you know someone who bought a Nikon stereo microscope well worth the money unfortunately it's a heck of a lot of money. At work they have a clone of probably the Nikon same pretty white color it's a microscope that's what they share in common but it just doesn't quite have I can't quite remember. I don't think it has the same working depth or he just doesn't quite have the quality but it cost a fraction of the cost and it does its job.
  • 3 months later...
Another thought on this microscope.   I have a nice stereo scope, so when I need close up work, it works quite nicely.  It is mounted on a large boom and takes up a lot of space, so it is a little cumbersome for lathe work.
This morning I had the idea to use the Bulova for turning.  I did a test and turned a 100um pivot using pivot steel.  It might work.  I wish I had a little more working distance, however.
Edited by LittleWatchShop
100um not 10um
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
