Does anyone know of a replacement movement that I can fit to my Seiko quartz world timer sports 150 watch? 5T52-6A5A and keep remaining original dial etc.
Also where may I find a manual, diagrams of workings to view of this watch?
all help welcomed 😄
 Hi Tim ,  aren't you based in the UK?      so I guess CousinsUk is the first place to check.
Haven't personally bought anything from them , but I hear about  esslinger, bestfit and few other material houses a lot, as well as ebay.
Good luck
Hi  Looking at cousins web site the 5T52A movement is obsolete  so you may have to serch ebay for a donor.  I take it that the original module is U/s.  I have attached the tech sheet for the 5T52A.   There may be an alternative movement which is compatible.
4579_seiko 5T52A.pdf
What the OP asked is, what is a possible replacement for the long discontined Seiko 5T52?
Not where to buy one, in which case the answer would be: nowhere.
Unfortunately there is no direct replacement for this vintage "world timer",  alarm, day date quartz mov.t, so either one manages to repair / restart it, or gets a donor watch.
